People w/ MKIII Midgets & modded A or swap engines
58Custom
My question: What radiator could I get that will fit in a MKIII without body mods that will work with a MKIII OR a 1500 radiator shroud (I have both) and will be able to cool well if I swap in a 2.0 Zetec/Duratec/Lampredi or a modified A series putting out 90/100HP?
Branson
supposedly the aluminum units for the sprite (griffin, speedwell etc.) will do the job well. Thats the route im planning on trying. Other option is the Valeo VW aluminum unit from like a sorrocco or something but that requires cutting the radiator uprights.
Dont know if the geo metro aluminum radiator would be adequate or not.
nomad
Tom: I'm running a Midget 1500 rad that I turned upside down and modifyed the inlet on in my A 15 Datsun engined Mk2 midget. I estimate around 80hp just by its performance. It cooled fine an the way to, and back from Midget 50. Electric pusher fan set to 190 degrees. 180 thermostat. On the open road temp stayed about 185. In town fan kicked on and temp never got over 195. Anyone attended from the west or south can tell you the drive was HOT. Mine is the cheap setup and if it had'nt worked I'm sure I could have found something for more money that would.
Kurt.
nomad
Tom: Yes, the 1500 rad sits behind the upright's and off to the side. I opened up some air flow to the side that is shrouded with a hole saw.
Kurt.
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
K 1068 mkIII wire wheel rub Spridgets 1
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
CARSINC MKIII Accelerator Pedal Spridgets 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
R For Sale Spitfire MKIII projects Triumph Classifieds 0
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
Pythias MKIII Springs WANTED Spridgets 8
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 2
B For Sale Fully restored 1965 Austin Healey Sprite MkIII .. Spridgets Classified 0
B Fully restored 1965 Austin Healey Sprite MkIII for sale. Spridgets 0
B For Sale Fuly restored 1965 Ausin Healey Sprite MkIII Austin Healey Classifieds 0
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
R BJ8 MKIII unknown parts Austin Healey 2
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
David Townsend Spitfire Spitfire MKIII Limited Edition Fine Art Prints Triumph 0
David Townsend MG Midget MKIII Limited Edition Illustrations Spridgets 6
AngliaGT IDIOT! - I need a L/H Midgett MKIII Hub Spridgets 10
AngliaGT Midget MKIII Ignition Switch Spridgets 0
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
R MKIII BJ8 Distributer Austin Healey 6
C AH3000 MKIII - Rear Brake Problem Austin Healey 1
PHerder ? about the rear section of the cockpit on a 1966 Sprite MkIII Spridgets 9
S Over arched Moss Motors leaf springs for Sprite MkIII Spridgets 33
bobmga62 MKIV transmission for a MKIII Triumph 12
V BJ8 MKIII Shift Austin Healey 6
J Another pic of '67 Ford GT MKIII Other British Cars 13
J Ford GT MKIII Other British Cars 0
Branson '65 AH sprite MKIII gauge sizes Spridgets 2
hymodyne GT6 Side indicators on GT6 MKIII Triumph 2
I Dash Indicators both flash, BJ8 MkIII Austin Healey 8
V Photo of a "correct" MKIII engine bay Spridgets 6
V MKIII dash replacement Spridgets 2
HAN8L1965 Headlight Dash Switch mkIII Spridgets 4
middie Datsun A12[S] motor * gearbox into a MkIII midget Spridgets 20
W Parting out a 1966 MKIII Sprite Spridgets 4
Dug MKIII dash style in a MKIV Spridgets 9
B GT6 Searching for a white RHD GT6 MkIII Triumph 1
C Will older doors/sliders work with MkIII Tub/Top? Spridgets 23
W Superperformance MKIII Seats Spridgets 6
TurnerSports222 Turner Ford GT MKIII on Ebay - Barn Find Other British Cars 5
Luke_Healey Install my own convertible top on a MKIII Sprite Spridgets 3
AngliaGT Wedge TR7 - Or Cortina MKIII? Triumph 10
Branson Beginning of my restoration - '65 MKIII Spridgets 77
Atrus MKIII midget body teim - how fastened? Spridgets 5
davelgee MKIII questions Austin Healey 1
D 67 3000 MKIII Austin Healey 9
T 66 MKIII found - need advice Austin Healey 4
