Painting an engine in place.
vping
Bronze
I figured while i wait for more parts to come in, I'd paint the engine in place on the '74. Any recommendations or tips?
Keoke
Tep here is a tip; anything you do not want over spray to get on wrap in aluminum foil.---Fwiw--Keoke--AZ- /bcforum/images/%%GRAEMLIN_URL%%/cowboy.gif
1965_MGB
Tape everything off that you don't want to get overspray on. Tape stuff that you figure there is no way that you could get overspray on, or you will. Murphy's law.
vping
vping
Bronze
How bout cleaning it off? What should I use to make sure it is grease free?
sqbsprite
Take off as many items as practical. Those plastic grocery bags work great for containing and masking items that are dangling. Spray on carb cleaner works great for degreasing. Just make sure everything is covered that you don't want damaged by the spray. Work from the top down and let gravity work for you. Use toothbrushes or a parts cleaner brush to loosen the thick stuff. Remember to cover your floor with several layers of newspaper which will absorb the mess. The carb cleaner evaporates fast and may require a once over again when you think it is completely clean just to be sure.
DougF
Carb cleaner will work. If you have a gallon of degreaser, some various scrub brushes and a garden hose will also do a good job. Put the degreaser into a spray bottle and go to town.
Once everything is clean, go over the entire engine with a good degreaser/dewaxer found at any automotive paint supplier. Let dry, and you should be ready to paint.
Prior to final wipe down, it wouldn't hurt to scuff the existing paint down with a Scotch Brite pad to give the new paint something to stick to.
vping
vping
Bronze
Existing paint? What's that? /bcforum/images/%%GRAEMLIN_URL%%/smile.gif Unless 1800's were painted brown, there ain't no paint left on her. If I remove the dizzy, should I pull it straight out & put it straight back in after paint? I should not turn the engine at all during it's time out right?
Tape the openings in the block or should I just stuff stuff in 'em?
jlaird
Good idea. Also smart to mark the dizzy and the plate so you can put it back almost spot on.
vping
vping
Bronze
Well so far the surprises have been that there wasn't an exhaust gasket. The Exhaust donuts were also missing. I went to remove the small oil line and bumped into the dizzy. It was loose so I have to reset it anyway. I just don't want it to be totally off.
jlaird
Point number one dizzy wire hole to number one plug. That's close enough for it to start.
Platinum
All which can come off should come off. Some old plugs with a bit of grease on the threads and half way wound in works to plug those holes. I keep a collection of plastic plugs around for this kind of stuff... every plastic cover/plug/protector I ever see. Pull the dizzy, disconnect any lines/wires. BAG everything you can, tape all with masking tape.
You may have an issue with rust removal from the block if I interpreted your "brown" comment. Mineral spirits and paint brushes work well to clean grease off. For rusty cast iron, maybe the heat resistant POR? I never tried it, so no opinion. I've used Ospho and wire brushes in past. Did this B engine "in-situ" but it was painted well before assembly the last time I had it out, so no corrosion issues.
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
R TR4/4A Painting engine in the car Triumph 7
DornTRoriginal TR2/3/3A TR3 Engine Painting Triumph 8
S painting an engine Triumph 9
hondo402000 TR6 Painting TR6 engine bay in progress[NOW] Triumph 14
J Painting Healy MK II engine compartment Austin Healey 8
KVH Painting the Engine Triumph 1
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
N Painting engine block Triumph 45
Bruce_B Painting 1275 engine - Questions Spridgets 44
HealeyDave Engine Painting Austin Healey 19
T Engine bay painting procedure? Triumph 6
T Engine bay painting procedure? Triumph 0
G Painting an engine block Triumph 8
K Engine painting Spridgets 0
S Engine Painting Austin Healey 1
ScottTR6 Painting engine compartment Triumph 12
S Spray-can engine bay painting effort Triumph 10
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
timsgolf Center Dash Switch Plate Painting Austin Healey 5
LAW75 Painting the Grille Surround Austin Healey 12
J Shroud Painting ["Finally done with these"] Austin Healey 3
GeorgeC Painting the Battery Austin Healey 0
J Painting Underside of Shrouds Austin Healey 13
J Painting a Frame and Substructure Austin Healey 12
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
S TR2/3/3A painting the floors of my tr3. Triumph 2
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J TR2/3/3A Painting floor pans Triumph 2
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
J TR2/3/3A Painting Triumph 11
S TR2/3/3A how to position pieces when painting Triumph 7
T TR4/4A Painting front hubs Triumph 2
S TR2/3/3A tr3 painting --spraying: vertical, horizontal ect... Triumph 8
69MGC T-Series MGTA Digital Painting 2 MG 0
B TR6 TR6 Painting/Restoration Triumph 2
69MGC MGC MGC Digital Painting MG 0
69MGC AH 3000 Digital Painting Austin Healey 0
69MGC Newest Digital Painting Aston Martin Other British Cars 0
B TR6 Painting a '74 TR6 Triumph 1
H Healey 100 Painting Austin Healey 5
KVH General Tech Questions About Painting Triumph 6
kennypinkerton General MG Rostyles. Painting question. MG 2
S TR2/3/3A painting the body tub “inside” Triumph 31
B Painting the Car - Corner Bead Advice Austin Healey 21
S TR2/3/3A I hate painting Triumph 8
J Final painting detail questions Austin Healey 16
dcoplan Suggestions for painting letters on dash knobs? Spridgets 6
Bob Claffie MGB Painting rubber bumpers MG 4
