MGB overheating MGB
golf
Member
Hello everyone,
My 72MGB runs at 195-200 on the highway.The faster I go,the hotter it runs.I had the radiater cleaned at Roppels and tightened the fan belt.Is this temp serious,and if so ,does anyone have any suggestions.Do the electric fans help much? Thanks,Ben /ubbthreads/images/graemlins/hammer.gif
Bruce Bowker
[ QUOTE ]
Hello everyone,
[/ QUOTE ]
Thats sounds high. Make sure the gauge is accurate. Not sure if your gauge has a voltage stabilizer or not. Heat can be casused by timing not right, water pump not up to snuff, wrong fan. Radiator is cleaned as you say but perhaps engine has blockages. Are you using a thermostat and is it working correctly and the right one?
Never used it, but Water Wetter claims to drop temp by 10 degrees or so. I would guess there is a problem somehwere and that electric is not THE answer at this time.
G
Mine is a '72 and here are some of the observations I have made.
I used to worry a lot about it and first tried a new temp sensor since the old one had a loose connector on it anyway. I then read higher. I repaired the connection and went back to the old one. The radiator core was eaten up some so I had it replaced. Still read the same. The guy even told me the new one had more cooling capacity. It didn't go up as high but still consistantly read just above the normal mark and a little higher in traffic. I checked the temp of the water at the radiator cap and it read 180 when the gauge was on the normal mark. I tried an add on fan from a local parts store ( I believe it is a 10") and that only helped a small amount in traffic. I mounted it on the front of the radiator to blow back through the rad and someone on here told me it shoould be on the back of the rad. I tried it without the stock fan with just the add on still on the front of the rad and it would not stop the temp from climbing. There isn't much room on the back and the stock unit would have to be completely removed so I never did it.
It still consistantly goes just above normal but no higher. It will cool down to the normal mark if it rains or at night. I just decided to let it go and not worry and it seems ok.
There IS a regulator and mine was ok but I forget the exact voltage it is supposed to regulate at. I think it is ten volts and if this is bad, it sure will make your temp show bad.
Bob
G
golf
Member
Thanks guys for your help.I know my gauge is correct as I have checked the water with an independent thermo.The gage does go a notch past normal,but will come back some if I slow down to 50.Maybe I'm a little too cautious.Thanks again,Ben
adam90009
i did notice yeasterday when i was driving 70 it was getting kinda warm but when id come to a red light it was at normal? oh well this are running smooth so im not goona touch it. it its not TOO broken dont fix it
Bruce Bowker
[ QUOTE ]
[/ QUOTE ]
I really would not concern myself with a notch above normal. I smidge under hot might cause concern.
aeronca65t
I'm running a 165 degree (F) thermostat. Works fine and gives me a little extra breathing room in hot-heavy traffic.
P MGB MGB overheating with a squealing noise from the engine MG 11
P MGB overheating 63 mgb solved :] MG 10
P MGB 63 MGB Overheating Help!! MG 18
Writer2022 GT6 Overheating after fitting air filters Triumph 4
S MGB-GT 1972 GBT overheating MG 10
G 79 Midget 1500 overheating Spridgets 2
Bob_Spidell Running hot/Overheating Austin Healey 44
M Coolant 'overflow' when not overheating.... what's up? Spridgets 34
W TR2/3/3A Overheating Bad Triumph 12
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
R TR2/3/3A Overheating 1957 TR-3 Triumph 13
R TR2/3/3A Overheating Triumph 0
F Overheating BJ8 Austin Healey 0
F Overheating BJ8 Austin Healey 20
C Healey BN6 water pump and overheating problems Austin Healey 11
R Honda Del Sol overheating Other Cars 6
B TR2/3/3A Overheating Problem Triumph 45
H oil cooler and overheating Austin Healey 12
J Spitfire overheating Triumph 2
mgedit TR2/3/3A Still Overheating ... Triumph 22
jlaird Overheating probs Spridgets 6
gubba TR4/4A TR4A overheating issue Triumph 4
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M TR2/3/3A Overheating incident Triumph 18
Lotuswins BJ8 Overheating - Need dimension Austin Healey 43
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
Norman Tri carb - overheating issue ???? Austin Healey 10
TR4nut TR2/3/3A Any thoughts on TR3A overheating struggle? Triumph 19
M Rough Running 99 XJ8 after Overheating Jaguar 42
histerical Overheating Spridgets 0
I Bugeye overheating - help please Spridgets 41
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
boeingpilot What is causing my overheating issue? Triumph 14
D TR2/3/3A Timing TR3A and Overheating Triumph 27
D 79 Midge overheating problem Spridgets 10
K TR2/3/3A Overheating TR3 - a few questions Triumph 34
regularman Pretty sure my overheating problems are gone. Spridgets 9
Monark192 Midget Overheating Problem - Continued Spridgets 10
Monark192 Midget Overheating Problem Spridgets 13
P Overheating Austin Healey 17
J Diagnostic [Overheating?] Question Austin Healey 7
KVH TR4/4A OverHeating TR4A Triumph 7
C TR2/3/3A overheating tr-3 Triumph 50
regularman Still with the overheating problem. Spridgets 45
T overheating Austin Healey 14
Webb TR6 Overheating TR6 Triumph 13
A T-Series Overheating light switch MG 5
kcbugeye1275 Overheating my story Spridgets 1
regularman Still trying to figure this overheating thing out. Spridgets 35
Webb TR6 Overheating TR6 Triumph 6
