Overdrive drive shaft?
bluemg
I have a drive shaft, when fully extended it is 32 inches from flange to flange. When collapsed it is 30 inches. I'm I correct in assuming that this is the drive shaft for a rubber bumper, tube type rear end, with overdrive ?
To my knowledge, there's no difference in drive shaft length for overdrive transmissions in rubber or chrome cars. I doubt it, but it's possible that the early OD units were shorter. I don't know that for a fact. PJ
x2
Never noticed a difference in length. I have installed overdrive trans in some of my cars and still use the same driveshaft.
Interesting. Moss lists three different drive shaft lengths,
DRIVE SHAFT ASS'Y., 30" std. banjo type axle
DRIVE SHAFT ASS'Y., 31.125", std., O/D tubed type axle, RD/GT from (c)138401on
DRIVE SHAFT ASS'Y., 32" O/D tubed type axle, RD/GT to (c)138400
Why do you suppose they do that if they are all interchangeable?
Cheers,
As usual, Dave has a good point. Researching this for my own curiosity, Here's what I came up with.
MGBs before Nov.1967 to #138400, took the Moss 268-100, 32" shaft. Indicates with OD
After Nov.1967 from #138401, took the Moss 268-090, 31.125 shaft, std & OD
All MGBs with banjo rears, takes the Moss 268-080, 30" shaft.
There's a slight misunderstanding here on my part, as I read, all MGBs prior to 1968 had banjo rears, yet Moss states that numbers proceeding 138400, 1967 back, takes a 32" shaft and banjo rear cars takes a 30" shaft. A little confusing to this old brain. Maybe one of you fellows can make a little more sense out of this. PJ
The reason I asked is my 79 B with a standard 4 speed has a 32 inch shaft, which appears that it has been running tightly compressed.
I am installing a 72 O/D transmission, and measured the O/D shaft (from the 72) and was surprised to find that was also 32 inches expanded, and the same when compressed.
Then I read the Moss catalog, which Dave and Paul pointed out, and became totally confused.
However with so many thinking the shafts are interchangeable it doesn't sound like a fatal error to intermix them.
All MGB GTs had the late style rear axle while the convertibles continued the banjo style diff until 1968.
The early non-synch transmissions were 1 1/8" shorter in OD form and thus needed the longer driveshaft.
