TR2/3/3A Overdrive drain magnets
TFB
I drained the Redline MT-90 from my rebuilt trans and overdrive.1500 miles and everything works as expected.I use the od,but not aggressive,mostly with a little clutch,except for when I forget its engaged until I get the double shift in second.
The fluid was not as clean as expected.It looked like bronze/brown paint being stirred with lots very fine particles.I strained through cloth and found no large particles.
Maybe most likely the new cone clucth material but not sure.
I am thinking of putting magnets to catch any metal but not sure where or how.Do they get wired to inside or outside of sump screen or do the just sit inside the screen bowl.
Any thought or suggestions sourcing or installing the overdrive magnets or trans drain plug magnets appreciated.
Thanks
Tom
Geo Hahn
I think there should be a stack of ring magnets with the big plug, just below the filter. Moss sells them:
https://www.mossmotors.com/Shop/SearchResults.aspx?SearchText=866-220&WebCatalogID=0
In addition I use a magnetic drain plug on the box itself. I make my own using a rare earth magnet so it can hang on in case a significant piece of metal is loose in there.
Of course there can be some stuff (possibly what you are seeing) unaffected by a magnet.
TR3driver
Great Pumpkin - R.I.P
What he said. The magnets were not original to the early units with the hex flats on the drain plug instead of notches, but there should be room enough for one or two of the later magnets even with the early plug and screen.
T
TFB
Thanks Geo and Randall.
After closer inspection what I thought were rubber washers to secure the screen bowl between the bowl and nut in case the bolt loosened are indeed magnetic .
Still surprised by the condition of the oil after only 1500 miles.
Thanks again
Tom
Geo Hahn
Yeah - they're not much to look at, I've wondered if replacements could be made from ordinary 'business card' magnets.
I do not recall what I saw on my first oil change after a rebuild, but certainly the first can be expected to be the worst as things wear in. I know I had a hard time getting into 2nd for a few months, then it got broken in -- I bet that process produced some 'gold dust'.
T
TFB
Thanks Geo,After just checking the Moss link I see I also may be missing the distance tube,unless its stuck and didn't drop with bowl.Will check and I guess make one if its not there.
Thanks again
Tom
TR3driver
The distance tube is only used with the earlier setup; with the hex flats on the plug instead of notches. There is also a bolt and washer that go through the tube, to clamp the screen in place.
With the later setup, all that is replaced by the spigot on the plug itself. There is no room for the bolt or the distance tube (and usually the threaded hole for the bolt is missing as well).
T
TFB
Thanks Randall.I guess my od ,or some of it, is earlier style because I have the hex plug and screen with bolt.I have tr3b trans with first synchro,and I believe some healey parts in the od.This was put toghether by rebuilder along with early top with fill hole and dipstick.
Thanks again
Tom
doc50
Question: Is there any steel that wears in the trans or OD?
Non-ferrous bronze synchros could care less about magnets.
Thom 1959 TR3
#34909L(O)
TR3driver
Every place there is a bronze synchro, bushing or thrust washer, it rides against a steel surface. The steel wears slower (hopefully), but it still wears. Likewise, the OD clutches ride against steel, which also wears slowly.
Plus on a TR3 'crash' box, there are the bits that get torn off of first and reverse gears every time they grind a little. I have seen gears with most of the teeth gone just from that!
CJD
Thom 1959 TR3
#34909L(O)
Every time you miss a shift you're putting steel in the oil.
Like you, Randall, I always assumed the bronze would take the wear before the steel shafts. Then I rebuilt those TR3 Rocker shafts. For some reason the steel rocker shafts wear many times faster than the bronze rocker arm inserts. Now I'm not sure how bronze and steel relate to one another.
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
C BN1 Overdrive drain plug question Austin Healey 0
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
M Overdrive drain plug Triumph 17
A Overdrive drain magnet-above or below screen? Austin Healey 10
Dave Richards Overdrive Drain Plug Gasket? Austin Healey 2
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
WALTER overdrive drain plug Austin Healey 20
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
T General Tech Spitfire overdrive, the sequel Triumph 3
T General TR Overdrive problem Triumph 4
R Gearbox and Overdrive Oil Level Austin Healey 18
C Overdrive Electrics Austin Healey 8
R gearbox and overdrive Austin Healey 1
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
R Overdrive dummy mainshaft Austin Healey 1
J Overdrive Cuts Out when... Austin Healey 11
J Overdrive Cuts Out when... Austin Healey 2
S BJ8 Overdrive Issue Austin Healey 6
S BJ8 Overdrive issue Austin Healey 10
F How does overdrive Annulus effect speedometer Austin Healey 10
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
W Healey 100 Overdrive stopped working Austin Healey 15
