Overdrive Almost Ready
KVH
I know, big deal. It's only been 6 months.
OK it's done and bench tested. Perfect at about 375 psi which is the recommendation per VTR for the older heavy accumulator spring. Big relief.
I'm ready to set the OD operating valve lift, and the "Articles" say the steel ball lift beneath the plug should be about .016. There are some differences of opinion.
If I use the adjustment lever as the guide--lining up the hole--I get .025.
Any opinions on which go with. Obviously, .016 is a smaller ball lift.
Also, if I bench test the solenoid do I just go straight to + current of a battery with the yellow and yellow/purple wires, connecting them together or do I need to remove the relay from the car and use that somehow?
From one continent to all others, across the hemispheres, from the arctic to the Cape of Good Hope and over to Cape Horn, I have a hunch who may have these answers.
Thanks.
JerryVV
Not who you were thinking of but I can help. Ground the transmission case and plus to the solenoid wire will activte the solenoid.
TR3driver
Great Pumpkin - R.I.P
I'd also go with the adjustment lever setting. .016" is too small anyway, in my opinion. .025" is just about right.
Contrary to what others have asserted, I do not believe that Laycock/Triumph ever expected the valve opening to control how fast/hard the OD engages. When they wanted a softer engagement, they reduced the displacement of the accumulator.
But the early units were supposed to engage hard. I even have a Laycock brochure that quotes a customer comparing it to a mule's kick.
hondo402000
Bam is right especially with the A type, and Bam is the sound your rear end will make if you are not careful
Hondo
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
T TR2/3/3A overdrive solenoid Triumph 3
T Spitfire Overdrive again and again... Triumph 5
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
T General Tech Spitfire overdrive, the sequel Triumph 3
T General TR Overdrive problem Triumph 4
R Gearbox and Overdrive Oil Level Austin Healey 18
C Overdrive Electrics Austin Healey 8
R gearbox and overdrive Austin Healey 1
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
R Overdrive dummy mainshaft Austin Healey 1
J Overdrive Cuts Out when... Austin Healey 11
J Overdrive Cuts Out when... Austin Healey 2
S BJ8 Overdrive Issue Austin Healey 6
S BJ8 Overdrive issue Austin Healey 10
F How does overdrive Annulus effect speedometer Austin Healey 10
S TR2/3/3A Overdrive drain plugs leaks Triumph 3
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
S TR2/3/3A Triumph tr3 overdrive wiring Triumph 9
W Healey 100 Overdrive stopped working Austin Healey 15
Graham H TR2/3/3A A type overdrive Triumph 6
Got_All_4 TR6 Quantum Mechanics John Esposito Quality overdrive parts Triumph 15
C TR6 TR6 Overdrive Wiring. Triumph 2
H Overdrive Problems Austin Healey 9
H Overdrive Problems Austin Healey 0
R TR2/3/3A Overdrive Solenoid Triumph 6
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Joe_Healey TR5/TR250 Overdrive Gear box oil Triumph 8
