Out with the old, in with the older
TR4nut
Just thought I'd make a quick post on my latest change of plans. A few months ago I bought a pair of Hurricane Ike TR3As . Lots of fun, but they were pretty worn out before the hurricane hit them. So 2 weeks ago, an opportunity presented itself to get a 59 TR3A project. In one day, I wound up buying the 59, and selling the two Ike victims. I think I did more daily sales than Standard Triumph!
Here's a quick snapshot of the incoming new (yellow) and one of the outgoing old. The old red one I believe is actually a 3B - but without commission plates unfortunately and with a blown engine. The yellow car needs work obviously (color change comes to mind), but it has a characteristic the other red cars didn't have - sheet metal is still good! Hopefully I'll make actual progress on this one.
Randy
Andrew Mace
TR4nut said:
...The old red one I believe is actually a 3B - but without commission plates unfortunately and with a blown engine....
Too bad about the commission plate. Any sign of body number plate(s) above the battery box? If so, a 3B would have only one plate, and it would have a TSF number on it (whether early TSF or later TCF series commission number).
TR4nut
TR4nut
Andy-
That's one of the other clues. Holes for only one body plate, smooth letters on the front cowl, emergency brake has a push on cover (like a 4) not a threaded cover, and engine has number TCF 576E. Engine also has a hole on either side of the block where it appears the crank and maybe one piston exited hastily. Drivers side seat also has the later style lever with the bakelite knob.
Randy
Perrymip
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]The yellow car needs work obviously (color change comes to mind)[/QUOTE]
It's hard to tell from a photo, but on my screen the yellow looks something like the period pale yellow. I always thought that a lovely TR3 color.
Brosky
I think that yellow looks good on any Triumph! Just my humble, albeit prejudiced opinion.
Tinkerman
Good move Randy. The project suddenly becomes less overwhelming! Keep us up to date on all of it.
Tinkerman
TR4nut
TR4nut
To clarify on the color comment - I happen to like yellow, especially on TR6's.. But in the case of this car, the yellow is definitely non-standard, and is somewhere between the period correct 'Pale Yellow' and the hot-roddy 'Mimosa'. I ordered the heritage info on the car so will wait to see what it was originally and will decide then.
kodanja
I'M A GREEN MAN, BUT THAT YELLOW IS AWESOME!
Gotta say, I'm liking the yellow too.....can you take a couple of pics outside in the sun? Flourescent lights can alter colors like yellow in pics.... :smile:
kodanja
mine started out yellow!
DNK
Good move going <span style="color: #33CC00">GREEN</span>
roofman
Boy you've moved more iron than me. I sold my TR6 last spring, bought a Mini, sold it at Christmas, bought a 75 Spitfire, then an 80 Spitfire, sold the 75 Spitfire, and kept the 80 ( for now). 4 cars in 1 year for me. We should start a used car lot.
TexasKnucklehead
I'm confused... exactly how many (parts) TRs do you now have? And how many complete cars can you make from what you have?
I can't wait to see them (in another week) but I'm a little dissappointed that I missed seeing the other hurricane victims.
Is the garage getting more or less cleared out?
Jer
TR4nut
TR4nut
Well, Jerry I confess to a little confusion myself!
Before I sold the Ike twins, I guess you could argue I briefly owned 6.5 TRs: the yellow 59, the twins, 2 TR4s, and about 1.5 TR3s completely in pieces in a storage unit. And then I realized maybe I have a problem! So out with the twins, and eventually the spare pieces will be gone as soon as I make sure the 59 doesn't need something. Then maybe someday I'll part with the project TR4, and get down to 2 TRs but I doubt it!
Here's a couple more pics of the car in the driveway, I don't think its an original color (definitely was resprayed) - and I confess its just a little too yellow for my tastes for a 3A. Will probably get swayed by the heritage certificate.
Hope to see you at our junkyard in a week - make sure you talk to me if you are missing bits for your own survivor.
Randy
Yep, I could totally live with that yellow.....certainly long enough to get the car sorted out.... :smile:
mctriumph TR2/3/3A Old trick on SU's Triumph 5
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
K TR2/3/3A Old school penetrating oil? Triumph 24
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
S TR2/3/3A old 4 bolt axle differential. Triumph 11
R Old History - List of USA TVR Authorized Dealers TVR 10
Popeye General TR Old robbins top in box Triumph 7
dougie Pistons - Old vs New Austin Healey 12
B Help for Old Men Restoration & Tools 15
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
roscoe New / old hard top Austin Healey 16
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
D Removing Old Radio Austin Healey 4
Bob Claffie New old car Other Cars 7
Mark Bailey Old tire rule? Restoration & Tools 5
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
T TR2/3/3A Question on old radio from my TR3 Triumph 9
DrEntropy Looking thru old pix Other Cars 8
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
B Dodge Chrysler Cool Vanilla = Old English White? Spridgets 7
R How old is "dead" FORUM Navigation Questions 5
D General Tech Old gasoline disposal Triumph 17
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
tinman58 General Tech Why I love old cars Triumph 1
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
B TR6 New [Old] Member Triumph 2
M Old English White Paint Code for early BE Spridgets 1
E Trying to ID some old classic car gauges Restoration & Tools 2
Zitch For Sale TR4 - old door cards Triumph Classifieds 0
AngliaGT Cool Old Truck + Spotted 1
D TR2/3/3A Recondition old wire wheels or buy new? Triumph 10
jfarris "Old Yeller II" Spotted 3
anarchy99 Help with new [old] Sprite hardtop Spridgets 17
CessnaTPA New Tires or Keep Old Ones Austin Healey 36
AngliaGT My Old Ford Consul Capri Other Cars 0
Answerman Restoration of OLD [pre WWII style] leather seats Restoration & Tools 5
jdubois Wanted Old BMH Original Technical Publications CDs Triumph Classifieds 0
doc50 New old member. Spridgets 43
doc50 New Old Member...sort of. Spridgets 7
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S TR2/3/3A On those old original coils Triumph 2
D never throw old parts away.... Austin Healey 7
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
JimLaney Liquids for 50 + year old Sprite Spridgets 5
