So, got my daughter off to camp for the next month or so (counselor), dropped in at a friend's mother's 80th birthday - she (the mother) loves us and is pi**ed off at all her children to varying degrees. I get home and decide it's time to get reacquainted with Ms. Triss. Get out there and
1. Figure out how to reassemble the overflow tank bracket and reinstall it (check)
2. Remove the rad and shroud so I can reinstall the fan.
2(a) straighten the fins and repaint where I scraped the rad pulling it out.
3. Examine the engine and realize that I should replace the fanbelt before I put the fan on.
4. try to figure out why the VB belt (right number I checked) is about an inch shorter than the existing belt and therefore doesn't go on.
5. Realize (good thing) that I had not yet put on the proper bottom bolt for the alternator.
6. Search for the right bolt
7. pull out and drop a box breaking the glass for my front signal light (beehive)
8. Find and install bolt
9. leave everything else off till I get a new belt tomorrow. (I wonder if there is a different alternator even though it is Lucas?)
10. Decide to work on the wiring.
11. Successfully fit the new grommet and feed the wire harness through the firewall on the fusebox side. Look for the dielectric grease to plug in the fusebox. No such luck.
12. Decide that I must do one thing so I will install my brand new Aston gas cap. Install the grub screws and try to figure out how to attach it to the fuel hose opening.
13. Remove metal fuel hose.
14. decide to email ebay seller for instructions.
15. grab a shower, a beer and watch Top Gear.
16. Did I say just 4 steps back?
