So, planned on turning the engine on the stand but couldn't find the chain. Did however get the water pump housing on to put the lifting loop.
Then turned my attention to the rear axle. Got the second side brakes rebuilt & installed, bearing installed, hub still needs to be painted but soon.
Here's tonights question. I can't get the axle stable enough to torque the pinion oil seal up to 140 lb. have it to 70 lb. but that's it - any suggestions?
thanks all
thanks all
