Oiling Carb
jhorutz
Member
What type of transmission fluid is used in Carb? I was told only to use Cartol Automatic Transmission Fluid, but am having a difficult time finding it. Any suggestions would be greatly appreciated. Thanks!
screenprinter
I've used everything from 3-in-1 oil to 30 weight engine oil. Generally the lighter weight the oil the quicker the engine will rev ( To a point).
I imagine you can use transmission fluid, but I really don't think it's that critical a point - Certainly not like filling a gearbox or rear end with the wrong type of oil.
Biff
Marvel Mystery Oil, any ATF fluid, any 10 to 30 weight non detergent engine oil will work. As pointed out already the heavier the oil the more lag in reving the engine, the lighter the oil the quicker the dashpots/needles can rise.
E MGB Oiling foam air filter MG 3
davidb TR6 TR6 oiling trunnions Triumph 7
Gerry M TR6 Trunnion oiling Triumph 7
davidb AH oiling the air filter Austin Healey 13
tahoe healey Oiling the starter Austin Healey 1
JohnnyMead TR2/3/3A Re-Oiling the TR3 Air Filters Triumph 0
C oiling chassis TVR 1
Hap Waldrop Ray's oiling system MG 5
jlaird Oiling your rack Spridgets 6
B TR6 Oiling the carbs in a TR6 Triumph 19
kyreb1862 MG Oiling Kit MG 6
Tinkerman Trunnion Oiling Triumph 6
jtb55 valve train oiling Austin Healey 2
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
