Oil Viscosity Transmission
ronzet
A quick query,
What is the recommended oil viscosity for the Tranny on a BN4??? Thanks, /ubbthreads/images/graemlins/confused.gif
Ron
ronzet
ronzet
Dave, As usual, you are a wealth of information... Soooo,
per your statement:
[ QUOTE ]
A lot of people are having very good results with Redline MTL which is rated 75W-80 & Redline MT-90 which is rated 75W-90.
[/ QUOTE ]
This is what you are recommending?? If so, My little 1500 MGA tranny will also be happy with that?? /ubbthreads/images/graemlins/confused.gif
Thanks,
Ron
ronzet
ronzet
ALSO.... The BN4 is an overdrive sideshift...if that makes a difference..
Ron
Dave Russell
Yoda - R.I.P
Ron,
There are so many different opinions on this that I hate to make a recommendation. Personally, I find that RL MT90 works very well, especially with OD.
ronzet
ronzet
Dave, Thanks for the (non /ubbthreads/images/graemlins/smirk.gif) recommendation...
I shall follow your lead... And the MGA??
Thanks,
ronzet
ronzet
John,
I have queried Redline.... will advise
ronzet
ronzet
John, I queried Redline. They are recommending, as you expected and as Dave had sort-of /ubbthreads/images/graemlins/smirk.gif recommended, MT-90 for both the Healey and for my 57 MGA 1500 trannys
Thanks for the help.... /ubbthreads/images/graemlins/thumbsup.gif
ronzet
ronzet
John, I have wandered around North County San Diego looking for MT90... NAPA, AutoZone, Pep Boys, and Kragen's do not carry it.... I see that you are north of me...
Where do you get yours???
ronzet
ronzet
I guess I should be more general in my query. Does anyone know where in SoCal MT90 is available off the shelf???
/ubbthreads/images/graemlins/grin.gif
Michael Oritt
John--
Not withstanding what Redline's product locator says I was unable to find their gearlubes (as opposed to their engine oil) in any of the chains in my area and wound up getting it out of a Baltimore mail order speed shop.
Keoke
Yeah Michael, I had the same experience and ended up ordering it on line---Keoke
John Loftus
[ QUOTE ]
[/ QUOTE ]
Baum's Auto Supply
25380 Marguerite
Mission Viejo, CA 92692
(949) 581-4041
Cheers,
John
ronzet
ronzet
Thanks to one and all for your input. It appears that I, too, will order the MT90 on-line...Or, thanks John, drive up to Mission Viejo to pick it up...
'till next time.. /ubbthreads/images/graemlins/cheers.gif
prb51 Oil Viscosity Austin Healey 10
RickB Cold weather and oil viscosity? Spridgets 8
Ed_K Dashpot oil viscosity Austin Healey 15
prb51 Heat, Oil Viscosity and Pressure Triumph 17
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
