I've been trying to get my Moss 13 row oil cooler installation completed. The cooler radiator is installed fine and the hoses are run, but I'm having no luck in getting the adaptor plate to fit between the oil routing pieces from the engine block to the filter bowl. When I face the hose connections forward the hoses don't have enough room before impacting the distributor. If I face the hose connections to the rear, the hoses don't reach with out kinking (and I think in this mounting direction the oil will run first to the cooler and the cooler people say it should first go to the filter). Has anyone used the adaptor plate supplied by Moss to integrate an oil cooler? If so how did it mount up and not have the hoses conflict with the distributor body? Maybe I got the wrong adaptor plate with my cooler. The Moss folks didn't really have an answer.
Hi Guest!
