oil capacity
jvandyke
I've looked and can't find a simple statement of oil capacity without filter change. Probably 3.5 qts but I need to know since I question my PO altered dipstick.
jvandyke
jvandyke
Duh, sorry, 1098cg.
Thanks, where did you find that in which manual?
And, if it's got an add on oil cooler?
Assuming the cooler and lines holds something. Seems a simple thing but I want to get the correct amount of oil in there and see what the dipstick says instead of the other way around.
HAN8L1965
After having the manual for 2 years I finally figured how it works. You have to start from the front page and each page finally builds up to a 1098 and beyond. I too could not find any capacities until recently. Everything just said top off. I figured someone was involved in the oil industry and wanted you to coat your floor with various lubricants.
To answer your question;
General Data page 5 which actually says 948 at the top but as I said the manual is cumulative.
The capacity is actually 7.8 pints
Mark
PAUL161 MGB MGB Transmission Oil Capacity ? MG 2
A 100-4 oil capacity Austin Healey 3
M TR2/3/3A TR3 TR4 oil capacity with aluminum sump Triumph 1
B Aluminium sump and the effect on oil capacity Austin Healey 8
R Differential Oil Capacity Austin Healey 10
R # qts of oil, Capacity of radiator healey mk II BJ7 Austin Healey 8
H TR4/4A TR4 Oil Capacity Triumph 20
V Oil capacity of Datsun gearbox Spridgets 1
J TR2/3/3A TR3 Oil Capacity Triumph 7
healeyboz oil capacity Spridgets 1
P TR6 TR6 Oil Capacity? Triumph 7
davidk TR6 Transmission Oil Capacity on a non OD TR-6 Triumph 5
healeyboz Oil Capacity Spridgets 9
B Oil Capacity 3000 Austin Healey 36
msoylemez datsun 210 trans oil capacity Spridgets 4
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
jerrybny Oil capacity after spin on adapter conversion Triumph 2
T GT6 Help on GT6 oil capacity Triumph 8
P Oil sump capacity Austin Healey 7
J Oil capacity MG 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
O TR6 Oil filter relocate kit Triumph 8
S TR6 Oil Pressure Light Triumph 2
Lin Oil sump sealant question Spridgets 0
H 280i oil filter TVR 2
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R Oil Filter Removal Austin Healey 1
Lin Oil sump torque value? Spridgets 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 5
L BMC A-series: Oil in coolant British Motor Corp 6
A T-Series MGTD oil pump bypass valve MG 0
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
M Oil Pump for BN2 Austin Healey 4
tr6nitjulius Oil flow view inside operating engine Other Cars 4
R TR2/3/3A Oil Leaks Triumph 24
tahoe healey Gold Sparkle in Oil Austin Healey 15
B TR4/4A Oil Drain plug size Triumph 14
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
J TR4/4A Oil Deflector Triumph 4
A T-Series Mgtd oil pump alterations MG 2
S Add ZDDP to gearbox oil? Austin Healey 29
E MGB SU CARB OIL 1965 mgb MG 3
Kurtis No oil pressure Spridgets 5
E Oil leaking from the Tachometer cable Austin Healey 5
Walter74 Oil sump AH spares Austin Healey 5
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Basil Neat trick for reading oil level Restoration & Tools 7
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
