Odometer repair
GaryBeu
Banned
So my odometer and trip meter quit working. The speedometer works but numbers won't turn. This is VERY important as I need to track mileage for my job. Where should I send this Smiths speedometer for repair? Any ideas will be appreciated.
Thanks,
Gary
ps. Money IS a limiting factor. : )
Platinum
We've tried a number of services over time but always go back to Nisonger .
Not the cheapest, but...
Mickey Richaud
Gary -
If you do send it out and need a temporary replacement, I have a couple lying around - let me know, and give me the numbers on the bottom of the dial. I'll see if one of these matches.
Mickey
drooartz
I've got the opposite problem -- my odometer and trip meter seem to work fine, but the speedo part is, um, a bit optimistic. Unless I really was doing 100 miles an hour up the canyon yesterday. And not passing anyone.
Platinum
Check to see if you have the 90 degree gizmo at the trans end of the cable.
G
GaryBeu
Banned
Thanks for the offer Mickey !! I'll let you know if we send it off.
JPSmit
Gary, speedos typically don't just quit - you might want to test it with a drill before you send it off - In my experience speedo issues are almost always cable issues.
G
GaryBeu
Banned
JP...the speedo works fine but the odometer doesn't. When I try to reset the trip meter it won't align the numbers to zero...seems to get to about 0000.3 and then will work until showing 1.5 miles and quits turning.
JPSmit
I see - sounds like a gear issue - here's a thought (BUT DON'T DO IT TILL AT LEAST ONE MORE PERSON CHIMES IN) I don't want you screw it up more - can you take off the glass as shoot some lube in and around the numbers? It may be binding - but, I've never worked on speedometers before so someone should now chime in that it is a dumb idea. On the other hand you might have nothing to loose.
Platinum
Hunt down posts by dklawson here on the forum, Gary. He has posted some excellent photos and info on speedo and instrument repairs. Another member has done so as well. May have been Paul Rego (Brosky) in the Triumph forum.
Don't spritz anything in the thing from the front, too much like usin' a shotgun to kill a mouse, IMO (sorry, JP :wink: ).
JPSmit
no worries boss- I don't know and am always open to learn
G
GaryBeu
Banned
Thanks JP & Doc...I won't spritz and I will try to locate posts by dklawson.
Gary
G
GaryBeu
Banned
Doc...I tried hunting posts on this from dklawson, etc. on speedo's. Just too many to search through. Seems to me if the speedo works then the gear in the trans must be working and the internal instrument parts for the odometer/trip meter must be at fault. Does this make sense?? Thanks.
Gary
Platinum
Yup. You likely have an internal issue with the gear driving the odo. I can't find the pages either...
And the 90* adaptor-lookin'-thingie at the trans end of the cable is a gear ratio device. If you use one from a non-OD box on an OD, the reading will be off by some amount... not recalling which way is which. And a "direct" connection will certainly be erroneous.
G
GaryBeu
Banned
Thanks Doc. My car is non-OD for whatever that's worth. I've emailed Nisonger for a repair estimate...now, if I can only figger out how to get the @#%!& thing out of the dash !!
Mickey Richaud
Tiny hands and rubber bones!
G
GaryBeu
Banned
That's about what I figured ! Nisonger says that with what is happening my speedo is suffering from old age and needs a rebuild. Now to come up with $175.00 plus two-way shipping...
G
GaryBeu
Banned
So...it's now time to remove my speedometer from the dash. Of course I can't ~see~anything back there and my Bentley manual has no information.
Am I correct that the speedo is held against the dash with a bracket in the back and I need to loosen two thumbscrews and remove the lens and it will come out the front? If so, it seems pretty easy except that I don't know where to find a 2 year old child with small arms and hands who can follow directions !
Thanks for any info on this.
Gary
Mickey Richaud
You'll need to remove the bracket that is held on by two thumbscrews. Then the entire unit can be pulled out.
But FIRST, disconnect the battery, just in case. And then disconnect the speedometer cable and the gauge light.
Depending on how much slack there is for the cable and the light, it may be easier to disconnect them once you've pulled the speedometer out a bit. Trial and error here.
Mickey
R Issue with odometer after repair Austin Healey 1
Boink Odometer repair? Spridgets 10
B General MG Does odometer record when flat towing. MG 5
Donald1107 TR2/3/3A TR3 Odometer Triumph 12
BoyRacer Odometer Reset Rod Austin Healey 4
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
K TR2/3/3A Dismantling Speedometer...getting the odometer pin past the case??? Triumph 2
K TR2/3/3A Odometer trip meter? Triumph 4
Darwin TR6 odometer reset cable Triumph 2
T TR2/3/3A Odometer resets for TR2-4A Triumph 7
S TR2/3/3A Odometer gears for the early pot metal speedometer Triumph 27
R odometer off by 25%, spedometer correct Spridgets 5
HEALEYJAG Ebay warning: Odometer fraud Jaguar 5
AndreL TR6 TR6 odometer cable Triumph 3
Lukens TR2/3/3A Jaeger speedo gears for the odometer. Free Triumph 2
P Odometer Finger Prints inside glass Triumph 9
HAN8L1965 65 Odometer Mileage Setter Spridgets 1
R inaccurate odometer issue Spridgets 9
T odometer bj7 Austin Healey 10
RynoBoy74tr6 Speedo, Odometer,Trip counter problems.... Triumph 6
hondo402000 odometer stuck at 99999 Triumph 7
John_Mc Speedometer/odometer questions Triumph 9
mrsprite Broken odometer? Spridgets 10
regularman Ok, odometer play time. Spridgets 48
regularman Odometer error is pretty big Spridgets 22
TR4 Jaeger Odometer Reset Arm Triumph 4
B Odometer failure Triumph 12
jlaird Help, BMW 218ti odometer light Other Cars 14
Slider748 TR6 Need help on fixing TR6 odometer Triumph 5
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
B TR6 Thrust face repair Triumph 1
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
C TR2/3/3A Frame repair and value Triumph 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
B Windscreen Motor Repair Restoration & Tools 6
O Jaguar rear window trim repair Jaguar 1
G Smith's temp gauge repair Restoration & Tools 4
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
H TR4/4A Fender/Wing repair how to do Triumph 5
H TR4/4A Advise asked for front repair Triumph 1
Bayless How to repair broken vent window studs? Spridgets 1
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
S TR2/3/3A Frame repair. Triumph 47
BritBite Transmission Repair Austin Healey 8
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Capillary Tube repair Spridgets 4
D General TR Frame repair - recommendations for NJ area Triumph 3
