Nissan Engine Question
14dna
I have an engine, and I wondered if it would be of value to any of you Spridget owners.
It is a twin cam 240 SX 4 cyl from an early '90s car.
It comes complete with a wire harness and computor.
It has a standard flywheel attached and an automatic trans as well.
I DO NOT know the condition of this unit as it was given to me.
I wondered if this would fit these cars.
It is too big to ship (I think) but I will give it to anyone who wants to pick it up.
I'm gone all day today (Sat) but will be home this evening.
If you think it's good, great, or if it is a boat anchor, tell me that too.
Thanks for listening guys!
Dave :savewave:
Little big for a spridget, maybe good for MGB?
I think it would be perfect for a big Healey, either a BN-1 or BN-2. It would replace the original 4 cylinder Austin bus engine with something more modern. It would probably weigh less than the original engine too. Too bad it doesn't come with the Datsun 5-speed. I had a Datsun 240SX from the early 80's and it had a 4 cylinder SOHC engine with dual ignition, 2 plugs per cylinder, big valves, and the cam was driven by a chain not a rubber belt. That thing just ran forever.
G
James_the_elder said:
. I had a Datsun 240SX from the early 80's and it had a 4 cylinder SOHC engine with dual ignition,.
James, you had a 200SX, not a 240SX. Yours had the Nap Z24 engine and IIRC, the 240sx had the SR20DE which is a really good engine. Some of the Z cars guys are pulling the six and putting the SR's in. They're alittle big for Spridgets, but can be made to produce stupid ammounts of power. They have a really good following and lots of support and aftermarket parts.
It's not a bad choice for a swap, but it will take some doing.
losmorob
I had an '82 200SX I bought used with 78,000 miles on it. Sold it with 360,000 miles on the odometer and still running strong. It would eat alternators about every 50,000 miles. Oil changes, air filters and a couple of spark plug replacements and that's it. Believe me, I'm a big fan. 5-speed, lots of power, fastback, sunroof and all the bells and whistles. I did disconnect the voice. Remember? "The door is ajar."
It was the transition year where the left side of the back of the car had a Datsun badge and the right a Nissan badge. And those funky rear window louvers. Loved it!
If I ever run across a decent one again, I'd buy it in a heartbeat.
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR6 Goodparts Nissan differential swap Triumph 3
WillR MGB Nissan head? MG 5
S 1986 Nissan 300ZX Other Cars 0
JPSmit Not British - Nissan GTR Spotted 1
waltesefalcon Nissan GT-R Spotted 3
Mickey Richaud Nissan Delta Racing 4
hondo402000 TR6 TR6 Nissan Differental installation Triumph 28
Banjo Mini pickup?! Lotus Exeige, and a Nissan GTR Spotted 4
NutmegCT Nissan Other Cars 3
weewillie rover p6 and nissan skyline Spotted 0
AngliaGT Nissan Skyline Other Cars 2
71tr Part No. for Nissan R200 diff pinion seal Triumph 0
jackq 90 Nissan pick-up Other Cars 3
A Nissan Patrol GR Other Cars 10
T Nissan wheels on ebay Triumph 0
T TR6 Nissan wheels on a Tr6 Triumph 26
rick_ingram Datsun/Nissan wheels MG 1
Simon TR4a Honda Fit, Toyota Yaris, Nissan Versa Other Cars 3
wkilleffer 1987 Nissan Maxima Other Cars 6
Basil Aw rats! More trouble with the Nissan PU Other Cars 2
waltesefalcon Nissan 240 SX LS1 conversion Other Cars 5
Steve_S Buy one Nissan, get one free! Other Cars 2
S Engine or Tachometer Odd Problem Austin Healey 7
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
G TR6 Engine Cutout, Black Smoke, Large Backfire Triumph 7
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
D TR2/3/3A Engine shakes as it is accelerated. Triumph 26
D Land Rover engine swop. Rover / Land Rover 0
BoyRacer Rover 3.5L (Buick 215 c.i.) Engine Swap Austin Healey 15
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Pool Dad 1960 TR3 engine serial number Triumph 14
J TR2/3/3A "TR3" painted on the engine block Triumph 13
D TR2/3/3A Engine mounts Triumph 11
R Engine Number Plate Austin Healey 2
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
alexisrexx TR6 Engine Hoses Kit or Hose by the foot? Triumph 6
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
D Engine replacement. Rover / Land Rover 0
pairof75's General TR Circulate fluids without engine start Triumph 10
nicko Strange Engine Noise Austin Healey 7
AngliaGT WANTED - Cheap TD Engine/Transmission MG Classifieds 0
tr6nitjulius Oil flow view inside operating engine Other Cars 4
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
B TR4/4A Engine ground strap Triumph 5
T Articles by Hap Waldrop reg engine disassembly and assembly Spridgets 1
