New steering wheel, ideas about adapting?
RickB
I got the new Mountney steering wheel yesterday now I have to figure out how to adapt it to my hub.
I have a spare hub for my MK2 Sprite so this will need to be adapted.
The hub diameter is a bit smaller than the holes in the center of the wheel so I will have to come up with an adapter plate.
It would be great to find something that's already round - I'm thinking something that looks like a big flat washer.
Here's a pic of the wheel, I'll shoot a couple pictures of everything tonight and post them.
tweety
Diameters? Hub, wheel inner, wheel outer, wheel screws.
I lucked out with my cheap steering wheel, it was the same diameter as my hub, just a different screw pattern. I was able to use self tapper screws that set into the old hub. Looks good and works good.
Off the top of my head, I'm thinking some .25" aluminum stock, an appropriate sized hole saw to get the correct diameter. I have some big hole saws, if you're lucky, I might have the right size and can cut the aluminum for you.... Just need to know the diameter
also might be worth searching industrial supply houses like Grainer and McMaster Carr. Grainger only sells to businesses that have an "account" McMaster sells to anyone with a credit card.
You would be amazed what they have.
RickB
RickB
Thanks Tweety, I'm thinking I may get another old MG horn push without badge and adapt it then put in a Sprite badge but the part between the wheel and hub is the sticker at the moment.
I will stroll over to the True Value store after work and see what they have that might fit. There's a lot of stuff in that place that works on these cars!
JPSmit
I just mounted a "personal" steering wheel by drilling 4 new holes and mounting on the existing hub - reversed the "ring" and mounted the horn - works and looks great. Did just google mountney and they seem to have adapters. I had an adapter for the "personal" wheel but the diameter was too great for my car. It is likely still available if it would help.
can you post pics of the hub?
Jim_Gruber
Someone on this forum was adapting old hubs / steering wheels to fit new wheels. On Bugsy my 68 for instance hub and wheel are all one and the same. I've got web site in England I'll post that had some interesting prices on hubs
Jim_Gruber
RickB
RickB
My hub is the same as the Bugeye, the PPO (or someone) had apparently cut up an original wheel and took the hub then drilled it to mount the $19 Fugly deep dish 12" POS wheel that came with the car.
At least the hub is still usable for me, and all I need is something like what tweety described above. Basically a donut that I can attach to the hub then attach the wheel to it.
I'll look at Chris' site - he is "The Man" when it comes to steering wheels!
bill_young
I adapted mine in a similar manner to that used by Chris S. but machined the tabs on the original hub flat and mounted the adaptor plate flush to the top of the old hub. It's made from a 1/2" thick disc of aluminum, drilled for the original spoke bolt pattern and the new wheel 6 bolt pattern. I used countersunk allen head screws to mount the adaptor to the original hub and then the new wheel fit flush over those.
RickB
RickB
Finally getting back to this, had guests for the weekend so no Spridget work was done. :frown:
I'll go double check the measurements right now.
Here's my wheel:
RickB
RickB
Ok - it's 2 inches across the opening for the hub and 2 3/4 inch from screw hole center to center.
The hub is pretty standard, spline hole a little less than an inch in diameter and the mount area a little over 2 inch diameter.
RickB
RickB
Well a friend at work says maybe his son in law can punch out a piece like what I need from scrap at his work. I just need to come up with a drawing, so I guess I'll get to work on that this afternoon.
I figure I need something about a half inch thick so the nut will be hidden, it's going to have to be about 3 1/2 inch diameter with about 1 1/2 inch hole in the center. It will be nice to have the screw holes already machined in.
I'll put the pieces to paper and see what happens, any additional thoughts before I get this done? Who knows what they will make this out of, they have a lot of scrap there and with plasma cutters and all the nice big machines they could do anything. I guess it will depend on what they have lying around.
Hairyone
I've brought a removable steering wheel & boss (ebay special). It comes with a spigot to weld to the original column & an aluminium boss that can be re-drilled if necessary to the new steering wheel.
Also means the car's a little more secure as you take the wheel with you.
"Wilwood Quick Release Steering Wheel Hub"
mccalebr
Here's a photo of the removable wheel and splined quick disconnect hub that will be going into my "Spridget Project"; both the bub and wheel are by Rebco and acquired from Summit racing. There are photos and info on the column modification here:
https://www.raysmg.com/rays_mg_midget_62_sprite_bodywork3.htm
Ray
tweety
I know this sounds crazy..... but could you drill out a hockey puck and use through bolts though the weel to the original hub?
RickB
RickB
I think that would work.
JPSmit
:bow: great idea, but you're from California, how did you know what a hockey puck was? or, maybe you thought - "what a strange name for a steering wheel spacer?" :jester:
tweety
I went to school in the Chicago, that's were I discovered how great a sport with two half times could be!
You would be amazed at the versatility of a hockey puck. I design and install home theaters and entertainments systems for a living. We go through about 50 pucks a year.... Need to shim up a projector... Hockey puck. Need ventilation between a cable box and a receiver, Hockey puck. Don Rickles needs a good joke, Hockey puck.
The clerks at Sports Authority must think I'm nuts when I clear them out of hockey pucks twice a year!
Ask me about Lacrosse balls... indestructible dog toy
scubabatdan
Hey just for giggles, save this picture and insert it into a blank word document and print it out, and see if the holes line up. I saved your picture of the steering wheel with the ruler in it, and cut out the ruler and did some measuring, and came up with this template :smile: Hey if it works you have template to give em.
Here it is:
I am curious if it works LOL
Just tested it off my preview and it is 3.75 in in diameter. The dotted line represents the yoke behind it. And the 3 inner holes are your original yoke bolt holes.
BTW YES I was bored!!!
Dan
RickB
RickB
Wow Dan, that was amazing!
Yes, it prints out the right size.
Thanks, that's really going to help.
Rick
A Steering Wheel Resto Paint Ideas ? Austin Healey 16
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Z For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
S Wedge tr7/8 quick release steering wheel Triumph 0
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
R Wanted wood steering wheel Jaguar Classifieds 0
K TR2/3/3A The Steering Wheel Nut Triumph 9
AUSMHLY Adjustable steering wheel removal Austin Healey 5
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
A TR2/3/3A How to restore a bluemels steering wheel Triumph 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
glemon General TR TR250 Steering Wheel Options Triumph 6
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
D E-Type steering wheel Jaguar 6
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
L T-Series 1952 TD Steering wheel removal MG 8
W Advice please on 1930's? steering wheel and rack Other British Cars 3
H Steering Wheel & Controls Austin Healey 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P BN2 new wood steering wheel install Austin Healey 5
M Original Bugeye steering wheel value Spridgets 3
GeorgeC Steering wheel nut size? Spridgets 3
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
BOBBYR Which steering wheel ?? Austin Healey 19
Drone Dog BT7 adjustable steering column / steering wheel Austin Healey 1
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
P BN2 Walnut Steering Wheel Austin Healey 10
J Horn/turn signal rotate independently of the steering wheel. FORUM Help 1
Z Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
PAUL161 T-Series New Steering Wheel MG 7
S TR2/3/3A Steering wheel covers Triumph 9
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
