blkcorvair
Im currently combining two projects. The 1500 series trans that cam with my car leaks terribly. I have an other good unit but decided to clean paint and replace various seals before the swap. I noticed upon teardown that teh bellhousing has no seal around the main shaft. It seams the collar has 5 or 6 grooves. Is this a leak prone area? Ive updated the gaskets and drive shaft seal as well as speedo oring. Also used some blue pipe dope on the plug threads. New Copper gasket for bottom bellhousing bolt. Any other pointers to achieve a leak free 1500 trans
