MGB New engine for the MGB
74WannaB
Congrats and good luck. I've got that task to look forward to in the next couple of months. I'm waiting for this western PA rainy, snowy wet winter to be over before I start. /ubbthreads/images/graemlins/thumbsup.gif
John Moore
Dave,
Have fun! Did you ask the seller if all the main caps are there? He mentioned the rods are missing, but it would be a pain if the caps were missing too.
David Brotchie
It was local, so I picked it up the day the auction ended. All the caps were there, the bores had hone marks, the crank journals look good, and the pistons and rings were new. The block is dirty from being stored for a while, and the newly machined surfaces have a bit of rust. The top deck and the oil pan surface don't look the best either. Hey, what can you expect for the price. I'm planning on having the top fly cut ever so little. I'm not sure if this will send the CR super high. Maybe combining this with a later low compression head will be the trick. We will see.
My plans for this car (79 B) are to switch to a Webber “Outlaw” down draft, headers, and modified head. I hope to be in the 105 to 110 hp range. Now that I have two motors, I will swap them every other year to get it smogged. It’s not that I want to cheat the smog laws, since I will have a working high flow cat on the Webber motor. The ZS carburetor and smog equipment absolutely don’t work. The car will be cleaner with the tuned Webber motor.
We will see.
S MGB MGB engine conversion MG 27
M MGB Early MGB engine compatible with later transmission MG 2
AngliaGT MGB '68 MGB Engine Removal Questions MG 5
D MGB 1963 MGB engine rebuild MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
G MGB Sick 1967 MGB Engine MG 1
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
Hap Waldrop MGB MGB 3 main engine porn MG 15
boxofparts MGB MGB Engine removal MG 5
toysrrus MGB `79 MGB Rdstr. Engine Bay Pics Needed: MG 3
BugeyeNJ58 Outrageous custom MGB - with Corvette engine. Spridgets 16
B MGB MGB tachometer erratic, engine cutting out.... MG 11
Gray_Cat MGB MGB OD Trans [and engine] For Sale in NC MG 9
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
S MGB MGB engine mounts - "extra" plate? MG 2
S MGA 5 bolt MGB engine conversion into a MGA MG 2
T MGB Engine Rebuild on 74 MGB MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
vping MGB MGB Engine Block Casting Numbers MG 2
aeronca65t MGB MGB engine work MG 3
T MGB MGB engine differences? MG 7
R MGB 80 MGB engine earth strap MG 11
R MGB MGB engine starting problems MG 9
Monark192 MGA MGB engine in an MGA MG 8
LeeMcKee MGB Engine Color MGB MG 2
S MGB-GT 1975 Engine in '71 mgb gt MG 2
PAUL161 MGB Highest Preformance Stock MGB Engine? MG 8
R MGB-GT MGB GT won't start after engine is warmed up MG 3
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
M MGB MGB VIN and ENGINE #'s MG 5
GreenHornet MGB MGB Beer Engine! MG 9
M MGB 1964 MGB 1800 engine MG 1
Razzoo MGB '73 mgb and 91 ford van engine swap... MG 11
T MGB '79 MGB engine mount replacement question. MG 0
J MGA MGB engine for MGA MG 15
V MGB MGB engine removal.... MG 1
L MGB MGB Engine Problems Again ? MG 10
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
