need carburetters for 1967 Austin Healy MK III
ronnie
I just purchased a 1967 Healy Mk III 3000 in pretty decent condition. It has been sitting for 15 years and the Carbs are missing ( were sent out for rebuild and never returned) My first project is to get a pair of 2" carbs. Someone told me ones from a Jag will work however I do want to keep it correct. I see Moss offers some, are they any good ( should be for $1500) I wouldn't mind some rebuilt ones for less. I then need to tackle the brakes and clutch as neither work from sitting. I assume the slaves need rebuilding.
ronnie
ronnie
where is the best place to get carbs for this healy and are there any better aftermarket carbs that work well. I heard webber makes some but are very pricy. Can anyone point me in the right direction.
soren_ak
dunno - im just still amazed how you guys keep finding nice cars "overthere" - lets see photos please /ubbthreads/images/graemlins/smile.gif and chek if the guy you bought it from have one more for meeeeeeee /ubbthreads/images/graemlins/smile.gif
ronnie
ronnie
I found it locally, just stumbled across it, have been looking for a long time. body is cherry and interior is original and mint. All I need to put it on the road is carb's, brake work Slave) and clutch work(slave)And it could use tire as these are dry rotted. I tring to convert to an alternater in place of the Generator and reverse the polatity at the same time(no Radio)will ad pictures later.
Simon TR4a
Ronnie the carbs for your car are the SU HD8, that is a 2 inch carb with diaphragms.
These were also used on some Jaguars and Rovers, and while the needles may be different they should be basically the same units.
Try ebay or used part ads, or post your question on the Healey board to see if anyone can help.
Simon.
Patton
Hi Ronnie,
Congrats on the Healey. What are you looking for, a set of carbs to rebuild or a new set?
If I were going to buy a new set I would get them from Burlen https://www.burlen.co.uk/ as they are the current manufacturer of SU. They are listing a set of SU HD8 AUD124 which are correct for your car for ÂŁ575.00. That converts to $1,050.74 at today's exchange rate.
Watching eBay patiently will turn up a used set, or join and post an email to healeys@autox.team.net as well the the Austin-Healey forum here and I will almost guarantee someone will have some for sale.
Good Luck
ronnie
ronnie
Thanks guys. I don't have any carbs as the old owner sent them out for rebuild 5 years ago and never got them back?? I know I need the HD8'S and want to keep it original. I understand that the Jags don't have diaphrams. I know about new ones at Moss for $1500 and the ones in the UK for about $1295 plus shipping to USA. I thought if I could find a set of used and have them rebuilt or $175 exchange that this route would work the best. I have checked Hemmings and Ebay and found nothing. I don't want to wait too long as I am anxious to get it on the road. Still looking! Thanks, you are all a bunch of great guys. I just joined the two USA clubs and can't wait to get started.
John Loftus
Hi Ronnie,
You could check with all of the SU carb rebuilders to see if they have a rebuilt set for purchase with no exchange. The following site has rebuilders listed if you scroll down. https://www.teglerizer.com/sucarbs/
Also, you might get more action on your request here if you post in the Healey forum (this is the MG forum!) No big deal .. one of the moderators will probably move this thread or you can start a new one.
Cheers,
John
Keoke
HI Ronnie, I would give British Car Specialties, Healey surgeons and Hemphils Healey Haven a call and see if you can not pick up a set of rebuildable core carbs.---FWIW--Keoke
Keoke
/ubbthreads/images/graemlins/savewave.gif Hi Ronnie, if you can not locate the carbs I can direct
you to a Professional BMC mechanic that will provide a rebuilt set for approximately $700.00.E-mail me off list if interested.---Keoke
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 7
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 7
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 22
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 7
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Help 7
JPSmit So I guess I don't need to lay off the churros after all Spridgets 4
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
N Electrical Issues Need Help Austin Healey 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
Got_All_4 TR6 Need a frame for TR6 Triumph 21
Bayless Need soft top for Morris Minor Other British Cars 5
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
vette Renewing Subscription, need help. FORUM Help 1
T Need a T-Shirt Entrepreneur Spridgets 7
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
F Help need reinstating my heater - BT7 Austin Healey 7
Bayless Need wheel bearing advice please Spridgets 4
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
madhouse Need Dunlop 165/R15 tires Austin Healey 8
Jim_Gruber 60th Reunion - Elkhart Lake - We need Stories from thise who attended Spridgets 0
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 0
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
