Need a Pickle Fork to remove MGBs Tie Rod Ends
Bret
Hey folks,
I need to replace both of my steering rack rubber boots that have ripped. Problem is I have the boots and the new Tie Rod ends, but I can’t find the correct size pickle fork or tool to remove/disconnect my MGBs Tie Rod Ends.
Any suggestions on a source?
Thanks in advance,
Bret
piman
Hello Bret,
it's up to you if you use this method that I learnt many years ago while working in a garage.
I would add that I don't as I have the correct tools but it could be a last resort method.
Take two large hammers and hit very hard, either side of the steering arm where the track rod end passes through. This breaks the grip of the taper. It's is not easy to do but does work.
Alec
[ 01-16-2003: Message edited by: piman ]</p>
Duane
I've used the two hammer method many times. Some smaller ball joints and tie rod ends can only get done this way due to clearance issues. Unless you have the special tool of course. On Hondas, you needed a small two part deal that was great if you worked at a dealership (which I did) , but I wound up using the 2 hammer method most of the time anyway.
Try Harbor Freight too. that's an item where so - so quality doesn't hurt all that much.
Duane
youngsmith
Two hammers do work! they aren't the "recomended" method, but it is my prefered method, but thats probably because of my vocation (blacksmith)
Tony
A
aerog
Where are you that you blacksmith? Ocala or something?
Cheers -- Scott
youngsmith
Tallahassee actually. I've been to the barberville shop near there a bunch of times though. Last year I made the trip in the spitfire, stayed with a friend in daytona.
Tony
youngsmith
Oh, and my friend graduated from D.B.C.C. with a degree in photography.
Tony
[ 01-17-2003: Message edited by: youngsmith ]</p>
A
aerog
I did some work for FDOT in Tallahassee and spent a few days there, but that was the only time. Nice ride from here to there along all the backroads though!
thegoodbeamer
Up here in the great white north they call those hammers a drift hammer.Alaways works for me. Bought a pickle fork and still have never used it.
Some think Minnesota is way up north.Fantastic winter here this year and decent temperatures. Winter here sees lots of salt on the roads so we don't drive our claasics. Must admit, drove the beam once in -50F as it was the only car that would start that morning.
looks good for skiing tomorrow and I only have to go 6 miles.We get great skiing and great summers. Must admit we do have some mosquitoes that can bite but we have lots and lots of spray or musk oil.
stever
Chuck, I lived five years in Duluth. Lovely area - especially in the summer - for driving. I left just as the "C02" devices to fight mosquitoes were being marketed. Was wondering if they work as the mosquitoes were definitely a big hassle!
thegoodbeamer
Steve.
Mosquitos are a problem around here.Mind you with the dry spring last year we managed to do with out them till the rains came in late June.You do need repellant to work in the yard especially in the evening.If you go camping you need to take extra weight in your pockets.[Not really].There are some good machines that are propane powered but at $1500 bucks I will keep the spray.Avon has a good skin lotion that works great and is real good for children.
Any way when you drive fast the mosquitos can't catch you.
also they don't bother us when we are skiing.
A
aerog
FWIW JC Whitney sells a lever-action tie rod end tool that is nearly identical to the tool specified in the original MG shop manual. I'd have to double check the measurements, but it looked like it would fit the MGB very well.
Eastwood also sells a kit of tie-rod removal tools for just over $100 that includes a couple of similar tools, plus several gear puller style removers.
sailing_glayva
Rather than removing the tie rod ends I just took a pair of vice grips and turned the tie rods out of the ties rod ends . This took only a few minutes and saved me the time of locating such a tool.
Brian
75B
Gary Pope
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by sailing_glayva:
Brian
75B
<hr></blockquote>
Hmm interesting approach .. well done.
A
aerog
I never followed up on my other post: One of the tools JC Whitney sells (probably available elsewhere) works absolutely perfectly, and effortlessly. The part number is 88ZX1770B, runs about $10. On the JCW website https://www.jcwhitney.com/product.jhtml?CATID=65281&BQ=jcw2 the balljoint remover is the one on the right side of the picture (NOT the lever-action version).
While the two hammer method (and others) work, this tool slips on and pops the tie rod out with a couple of twists of a wrench.
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
