TR6 My TR6 Project
Scot1966
I have been putting some pics together, and there are many to get to where I am now. Here is where I started working on the tub. I did a few small weld repairs to the tub before taking it off the chassis. I'll be adding more pics soon. Thanks Justin!
Under the front deck section
Welded back together and wing on to check fit...
Scot1966
Scot1966
The rear deck had a small spot of rust on the drivers side...
First I had to fix the inner wing...
2 patches in the corners first...
Inner wing finished and deck patch fabbed...
Scot1966
Scot1966
Top view...
[imghttps://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash3/s320x320/541187_109936609138972_100003679008519_54534_909846515_n.jpg[/img]
All welded and blended. Just a little filler should do it...
On to the rear valance. I am still on the fence about replacing the whole thing. I am not sure if I like the final result, so I will think about it...
Cut out...
Scot1966
Scot1966
I wish Moss would make patch panels for the outer corners of the rear valance. It seems to be the norm with the 6's. I formed one and welded it together...
It fits well, and lines up with the wing great...
The passenger side goes all the way into the black!
This one took a while...
That is all the weld repair I did to the tub before I took it off the chassis. Stay tuned for body removal/frame repair.
Scot1966
Scot1966
I braced the tub for support front to back, side to side, and diagonal. It is pretty solid...
The engine hoist worked great for taking the body off...
All clear...
1st light seen in 36 years!
Scot1966
Scot1966
tdskip said:
Nice work Scott - please do keep us updated.
Thanks so much ! I have a few more pics to get to the current state of things. Here's the frame stripped and flipped over...
Here is the old repair the DPO did with the body on. The original T Shirt had been cut off and the frame had these 1/8" plates welded right over rust in the typical spots our frames suffer. Then, this square was welded on to take the place of the T Shirt. The trailing arm mounts had been replaced and were plenty strong, but I chose to cut all of this previous repair off, cut out the rust under the old patches, get rid of the mounts, and use new mounts from Moss. One side at a time...
Scot1966
Scot1966
Here's the driver's trailing arm mount removed and the rusty spot where it mounts cut out...
This is the extent of the rust that was under the patch that was welded on this side...
I fabbed a patch and welded it in. I have been welding in the aerospace industry for many years and have this to say to anyone learning, or wanting to learn to weld; It does not matter what your welds look like because it gets ground off anyway. Just make sure you have penetration. I skip all around with SHORT welds to keep the distortion down. The inner edge of the patch is plug welded.
All flushed and ready for the trailing arm mount...
Scot1966
Scot1966
The new trailing arm mounts come in 2 pieces, so you have to weld the C shaped cover on. I used a pneumatic flanger/hole punch to make the holes to plug weld.
I used a TIG welder to plug weld it together. TIG welding means no grinding the welds when you are done. The welds are very clean and you can make them flush while welding.
It took a while to fit the mount to the frame. All the weld from the previous repair, as well as the small bits and pieces from the factory mounts that were still there had to be ground off with a cut off wheel using a die grinder, and a body grinder.
This is where I presently am. The mount is in place against the jig I made to make sure it is in the right position before final welding.
AltaKnight
Wow, wish I could weld like that!
Scot1966
Scot1966
sundown said:
Can we say a pro at work.Nice job
Thank you for the kind words, but a pro I am not. Just a backyard hobbiest that can't stand things hacked. One thing I have learned as I got older, is that I would rather take a little more time, and do it right. And even then, I am usually not satisfied and end up selling it!
Scot1966
Scot1966
Today was a pretty "Good Friday"! I got the 1st trailing arm mount all welded in...
I knew this side would be the same as the other! Rust never sleeps...
What's lurking under your T-Shirt? Whatever it is, just cover it up like the DPO did!
Just kidding, cut it out before you cover it up!
justin_mercier
For protecting the insides after the welding is done, eastwood has a nice spray internal frame coating that I used with my frame, and it seems quite nice. Your welding looks awesome. My welding when I did my frame was the first time i've welded anything outside of a forge. Forge welding and electric welding are very very different >_<
Thankfully, as you said, once you grind it down flat, you cant tell how ugly the beads were =)
Scot1966
Scot1966
Is it similar to waxoyl ? Once my frame is blasted and POR-15ed, I planned on using waxoyl for the entire frame. I drilled the trailing arm mounts so I could get in all those crannies too. What was the foam you spoke about in your post that everyone was so horrified about?
justin_mercier
https://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html
This is the product that I was talking about first, an internal spray paint.
The foam that everyone was horrified about is as listed on the ratco page. I actually havent used it yet. I purchased the foam this last fall online from the place i found it the least expensive and the foam i got arrived with a sticker on it, "expires september 2011" and i didnt get it till october, and then the company i bought it from wouldnt take it back or refund, so ... yeah not happy, and wont buy stuff like that online again. by the time i finished trying to fight with them for a return / money back it got too cold to even try to use the stuff i had. I'll break a can out and test it to see if it's still good past expiration and if so, may use it still.
Scot1966
Scot1966
Justin,
How many cans of the Eastwood Internal Frame coating did it take to do your frame?
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
D TR6 Researching potential next project car - Looking into TR6 Triumph 5
C TR6 72 TR6 Project. A few new pics Triumph 5
Decado TR6 TR6 project Triumph 6
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
A TR6 New project -73 TR6 Triumph 7
T TR6 TR6 resto project/parts car in SE Mass Triumph 2
hondo402000 TR6 71 TR6 Rewiring project Triumph 11
M TR6 A video on how my TR6 project is doing Triumph 7
hondo402000 TR6 Rewiring Project for TR6 Triumph 7
G TR6 Possible TR6 Project ? ? Triumph 1
A TR6 Finding TR6 Project? Triumph 22
G TR6 Possible TR6 project? Triumph 2
L TR6 TR6 Front Suspension Resto Project Part One Triumph 11
beaulieu TR6 TR6 project with one dead cylinder ? Triumph 10
Steve TR6 TR6 Project available, WI Triumph 2
Steve_S TR6 Wanted: TR6 wheels for test project Triumph 0
milemarker60 TR6 TR6/M3 Project Up-date Triumph 15
H TR6 New TR6 project... where to begin? Triumph 27
Brosky TR6 Another V-8 TR6 Project Car.......... Triumph 1
Steve TR6 TR6 Project Car for sale Triumph 0
T TR6 Wanted project TR6 in the south Triumph 0
G TR6 Rotisserie for a TR6 restoration project Triumph 12
BierRunner TR6 TR6 Gas Pedal Triumph 2
nichola TR6 Another TR6 back on the road Triumph 1
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
E TR6 74 TR6 - “ A Post Seal” Triumph 0
J Wanted TR6 seat vinyl Triumph Classifieds 1
E TR6 Temp Gauge - 74 TR6 Triumph 11
K TR6 tr6 not starting Triumph 8
E TR6 74 TR6 Renegade Dash Wire Triumph 7
BwanaJoe TR6 TR6 radiators Triumph 4
E TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
M TR6 Fuse box wiring mystery Triumph 9
M TR6 Windshield Trim TR6 Triumph 14
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 Procar Pro-90 Seats in the TR6 Triumph 0
E TR6 TR6 top dash trim paint Triumph 2
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
F For Sale Wheel Trim Rings Triumph TR6, $95.00 Triumph Classifieds 0
P TR6 TR6 Frame Stiffener Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
C TR6 Latest TR6 updates and pics Triumph 10
P TR6 TR6 Horn Relay Problems Triumph 8
tr6nitjulius General TR TR6 Triumph 0
Sherlock Triumph TR6 (rather modified) Spotted 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 0
