My B is moving under it's own power
DavidAGO
For the first time! got it started and running roughly, but running on Friday, got the clutch and brakes bled on Saturday. the clutch is a bear to bleed. I had put on a new slave and master,and the slave had the inlet and the bleeder reversed, but I could not switch them and have it work, the high end where the bleeder should be did not have the bevel cut for the bleeder screw, so I had to unbolt the slave and hold it with the bleed screw up to get it to bleed. Now the fun stuff, sorting out all the little British gremlins. I have a long list, and at the top of it is getting the carb sorted. It came with a big honking Weber DCOE sticking out the side, and in the trunk was a new Weber downdraft with manifold. I still have the DCOE on it, but need to get rid of it, I am not smart enough to get it set up.
The engine compartment is a heinz 57 of parts; It came with a 25D distributor on, with a 45D4 and another unmarked dist in the trunk. It took the unmarked one with the electronic ignition out of the parts car, of unknown origin, to get a dist that worked. I have to sort out vac advance, and hope to eventually find some SU's somewhere and get back to what God intended for a British car.
The fun begins.
DavidAGO
[/img]
I forgot about photos the first time, had to get them uploaded to Photobucket
JPSmit
woo hoo! first time is a milestone, congrats, now it is tuning.
(BTW pics please!)
mgbsteve137
Congratulations!!! I would think this is a condition much to be desired. <GRIN>
I thought the clutch slave cylinder bleeder problem was a known issue and all that was necessary to fix it was to reverse the hose and bleeder connections. Check the Moss web site for their fix notes. Is it a Moss part?
PAUL161
David, The DCOE is a much better carb than the downdraft, which is probably a 32/38. The 32/38 has a hesitation problem on acceleration which is difficult to get out. Some don't mind it and others just put up with it and some will swear by it! If the DCOE is in good order, I'd leave it on. Me personally, I'd put the SUs back on! JMHO. PJ
Platinum
Going to the downdraught Weber is going frying pan to fire, IMO. Clean the DCOE inside and out before you condemn it. The manifold you're forced to use with the DCOE (due to the booster/master cyl.) is less efficient than the configuration shown in the BMC Competition Manual but still better than the one for the DGx, by far.
Valve lash adjusted correctly?
You might consider uncapping the crankcase vent and at the least routing it with a hose into a "spill bottle" of some sort, too.
British gremlins? Nahhh. Most issues with these things are as a result of jack-leg mechanics putting "good enuff" repairs on 'em.
The 45D dizzy would be my choice for ignition, shortest distance between the trunk and engine may be through shipping it to Advanced after talking with Peter about the DCOE and what you know about the engine's state of tune. Was the thing possibly cammed?
DavidAGO
I am not sure if it is a Moss part or not, but it was a known issue with me. The problem was that the proper place for the bleeder did not have the proper bevel cut in the bottom, so I could not switch the bleeder and hose and get a good seal, it would leak. I have it working now!
David AGO
DavidAGO
Hummmm, who is this Peter and what wizardry does he perform? I also may have to learn about DCOE's, I do know the throttle cable linkup is a no-go, and the individual parts do not show up in my (older) Moss catalog. Wherer do I go to obtain proper weber parts?
David
DavidAGO
More pics [img:center]
[/img]
[img:center]
[/img]
The odometer shows 53,000 miles, that matches with the title I got with the car.
These B's have a lot more 'stuff' in them than my MGA's!
David
Platinum
:lol:
Yeah, concessions to modernity. :wink:
My bad... I meant Jeff, not Peter, at Advanced. We'll find the contact info directly:
Advance Distributors...
17495 Marystown Road
Shakopee, MN 55379
(612)-804-5543
https://www.advanceddistributors.com/
As for Weber bits, if you're looking for cable and linkage, try bicycle brake cable. May need to MacGyver linkage. If you need jets and such, there are a few places. Google DCOE Weber and pick. :wink:
AngliaGT Skip Barber Racing School moving to VIR Racing 2
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
V Moving into New Grage TVR 8
Jim_Gruber Bugsy -Moving forward - RF Suspension is out Spridgets 3
KLUTZ FS. My '64 B, OD, Love it but moving on... MG 7
Sopwith_Camel mg guy moving up Jaguar 31
rlich8 Timing Mark Moving Around Triumph 21
boxfullofyertoys Moving sale! No reasonable offer refused! Spridgets 2
tahoe healey Moving car with out coolant Austin Healey 5
tomshobby Moving on! Spridgets 4
apbos TR2/3/3A Ideas for moving my TR3a????? Triumph 4
J fender cover out of moving pad Austin Healey 6
T OT - I'm totally bummed. FJR moving to a new home Triumph 13
theleisure Moving North, Looking for '66 Hardtop Spridgets 7
T TR6 Moving TR6 gearbox to TR4a - any issues? Triumph 5
Tinkerman TR2/3/3A Moving & Setting Body on the Frame TR3A Lifting P Triumph 10
drooartz Moving high beam switch Spridgets 13
T The "Sock Zone" is moving into my garage.... MG 1
tahoe healey Moss moving? Austin Healey 12
eejay56 Spitfire Help moving a Spit in Salem Triumph 13
mrstinson Moving and need help Spridgets 8
Trevor Jessie Moving wiper motor Spridgets 6
tahoe healey Dixon is moving! Austin Healey 14
toysrrus toysrus [Russ] is moving to the Jaguar Section Triumph 23
beaulieu moving a car cross-country - by furniture movers? Restoration & Tools 16
I TR6 69 TR6 static vs moving timing - what is better? Triumph 6
K TR2/3/3A TR3...Moving the Coil & Petronix Wires Triumph 3
T TR6 TR6 died - moving plate earth lead fired Triumph 15
JFS Moving Tool Chest Restoration & Tools 5
kyreb1862 MGB Moving an MGB MG 26
S Car moving/transport company suggestions? Other Cars 20
drooartz Moving on to the generator Spridgets 32
zimmy car is jerky when moving Spridgets 4
soren_ak question regarding moving a car from England to DK Austin Healey 2
Stewart Moving around an MG MG 6
T GT6 moving the body on a gt6 Triumph 4
kindofblue TR5/TR250 TR250 Latest - Moving Ahead Triumph 16
T Moving Gas Tank Triumph 5
S MGB mgb roadster : sticking the hood to the rear moving bar of the cage MG 12
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
J TR2/3/3A Pads under new floor Triumph 7
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
