Mr.Clean Car Wash
A
aerog
Yes it's true. This week I succumbed to advertising, internet hype, and my own curiosity - and bought a Mr.Clean "AutoDry" kit at Sams Club.
Some background: I never worried about water, or car-drying before I moved to Florida seven years ago. The water I had in Virginia was such that I just left the car and it would dry ok without any big problems. When I was in the mountains I used the corner do-it-yourself car-wash stall and would drive away, never saw much spotting.
Florida on the other hand, has been horrible. Left to dry without towels or a water blade the car would be drenched in mineral deposits, sometimes hard enough that polishing was the only solution. This was true with a functioning water softener, and later they switched us over to a community-wide double reverse osmosis treatment system (tons better, but still not very good on the paint).
Over the years I've come up with my own solution to washing my cars. The MG gets a careful wash, tons of water, and to remove the bulk of the rinse water a gentle brush with a fresh California Water Blade (soft silicon). Remaining water is softly blotted and wiped away with a Fieldcrest Royal-Velvet towel. I've never had a problem with spots or streaks, or scratches - but it takes forever.
The Miata gets dried with "water", using a gentle stream from an open hose to sheet the bulk of the water off the car. Remaining spots are taken care of with the towel.
Even with diligent effort any spots left to "air dry" will leave a slight and annoying mineral deposit. A few years ago I toyed with trying to build a dedicated filtration system just for washing the car, using filtered water in tanks as a final rinse...
Enter "Mr.Clean": I washed the Miata using the Mr.Clean directions; in their system handle you fill a small reservoir with their "special" soap (probably similar to the other self-dry washes found in the autoparts store), and load up a good sized double-filter cartridge - then go to work!
The system isn't any different than the typical washing process: you pre-rinse the car (with unfiltered water by the way), then from top to bottom you soap up one section of the car at a time using the "soap" setting on the handle and a good quality sponge or mitt. When the car has been completely soaped up you rinse it down good - again with unfiltered water. When all the suds are finally gone you switch to the special "filter" position on the handle and are greeted with a very fine "fan" of spray. The instructions say to wash all the rinse water off the car using the filtered water spray (from top to bottom), then sit back and watch the car dry.
The Results? Well, I wouldn't exactly say the car "dried before my eyes" like the instructions say...but then again it's sopping-humid outside and the afternoon-sun was already well behind the trees. After 10 minutes the edges of the body panels were starting to show dry areas as the water was slowly sheeting off the car. Unwisely I decided to run around the block to dry the wheels (and brakes), and when I got back from that short 1.5-mile 30mph jaunt, the water went from a flat solid sheet to beads and spots!
I was kicking myself! I'd ruined it! Time to rewash!
Not so fast... I started looking at the paint really closely (the Miata is a very dark green), and as the beads were drying they weren't leaving even the slightest hint of a spot. None! So I left it - spotted with water beads and streaks that would normally require a good polishing and waxing for me. Amazingly there were almost no marks on the paint at all once it all dried up. I'll admit there were one or two small spots around the bottom, but overall the results were impressively good!
Comments
Pros: I think the brute-force advertising claim of "AutoDry" misses the point with this product. Although they mention it in the TV spots, the real charm is the filtered water...which was exactly what I was looking for in the first place. No spots - even after accidentally eliminating Mr.Clean's special "sheeting" action. My goal was to have a spot-free finish and I got it, without much effort. I'm happy with the results!
Cons: The obvious first detractor for this product is that you obviously need to keep replacing filters and buy their soap (although I'm going to try other soaps too). The handle is well made, but the spray-pattern for the non-filtered rinse is a hard narrow jet. I usually use a high volume flat fan pattern that pushes suds and dirt off in a controlled manner and don't care for the "jet" approach. With that in mind I think you could easily use their soap in a bucket in a "tradition" manner (or use another soap with experimentation), and your favorite nozzle on the hose - just switching to the Mr.Clean handle for the filtered water. That's probably what I'll do next.
Our first experience with Mr. Clean was not a positive as yours. We still had spots on our Forrest Green Austin. It is back to the drying towel for us!
I got one of these for Father's Day, and after 2 washes on the Caddy and one on the TR, I find that it does work pretty much as advertised. The dry isn't "perfect", but for every day drivers it's OK. And there's a lot of surface on the Caddy to towel dry. /ubbthreads/images/graemlins/wink.gif
I havent used it myself, but the corvette guys have been discussing this very item for awhile. Anyway, one guy tried using different soaps and found that they didnt work at all. he wasnt using the self dry types though. anyway keep us posted on your results /ubbthreads/images/graemlins/smile.gif
Re: Mr.Clean Car Wash - UPDATE
I should have updated this awhile ago but... here it goes:
Clog?
So after using the new Mr.Clean Car Wash "handle" 7-8 times on the Miata there I was, just putting the final rinse on when halfway around the car the water suddenly and immediately just stops. I managed to get a dribble out of it, but thats it. Hmm - a clog? I took the whole thing apart and it looked clean, even back-flushed it... still clogged up. Turns out the filter clogged good and solid that quickly. So, I now plan on getting a new filter after 5-6 washes just to have one on hand.
Different soaps
I for one do not like their soaping system - and I'm not crazy about their soap. I've used "self dry" soaps that do precisely what Mr.Clean's do, but Mr.Clean's seems to leave a film I'm not happy about. I also don't like the idea of just spraying soapy water on the car then rubbing it around with a sponge that doesn't get flushed out with a bucket of water. So, I started using Meguiar's NXT Car-Wash in a bucket just like I always had been doing... in fact, I disconnected the Mr.Clean handle completely and went back to washing the way I always have - only using the "handle" for the final rinse. I didn't expect much the first time I did it, but the final results were absolutely the same as when I used the Mr.Clean wash...not a spot in sight.
As a fellow British car owner, I will put this out to everybody. IF you would like a free 2oz sample of my carnauba car wash to try with this Mr. Clean gadget, I will supply you with one. Just email me your address with a phone #, and I will send it on. No hype, I promise I will not enter you into the email list from heck as I would not like that to happen to me (although I have already been entered). Let me know what happens when you use my product with their gadget.
