MOTORSPORTS - Battery Location
tony barnhill
Great Pumpkin - R.I.P
Is there a better place than the stock location for an SCCA SOLO car?
jlaird
Can't resist this sorry in advance.
The back seat is a better place.
Well, I can't think of a betteer place. Low, keeping the weight (C.G. & roll ctr.) where it should be. Anyplace else and it's another foot or more higher. Fore or aft further and you add it to bias considerations. I'd say don't go looking for more work for less return.
Just my opinion.
tony barnhill
tony barnhill
I'm thinking the same thing, Doc - leave it where it is...removing the battery box would lighten a bit but I think an Optima down there would be okay...I've already removed the box behind the driver.
It'll keep the necessary weight of the battery low. But isn't roll center a result of suspension geometry and not where the weight is in the car?
tony barnhill
tony barnhill
Kenny - I think lower center of gravity (weight down low) helps...but, then, what do I know about racing? Doc & the other guys know better
MGA Steve
[ QUOTE ]
[/ QUOTE ]What is the front vs. rear weight distribution in the GT now, Tony? How much weight have you removed from the front vs. the rear? That may tell you if somewhere other than under the rear seat (or where the rear seat once was) would provide better handling. I don't think there is any way to get it any lower, is there? Or to put it under the front passenger seat to help balance driver weight?
Best place for any moveable weight is going to be low and between the wheels, as close to the middle of the car as possible. The factory spot is pretty good... It sortof balances the drivers weight being on the passenger side. Anything closer to the ends of the car increases the amount of energy needed to turn the car, and stop turning too.
I learned that much flying aerobatic Radio controlled airplanes for 10 years, and racing R/C cars competitively for 3 years.
One other suggestion I just thought of, but it's probably too late to change now is to have the fuel tank where the passenger seat was. That would eliminate changes in handling as the tank empties. I've seen this in other race cars and wondered why, but it suddenly made sense.
tony barnhill
tony barnhill
Think I'll leave it where it is
Kenny, the gas tank has to be separated from the driver by a metal partition..I'm bending aluminum to cover it right now!
Good rule. It'd suck to be dowsed in gas during a wreck. Are you allowed to use race fuel? Or is there a Pump Only limit? I know where you can get nitromethane in Birmingham to add to the pump gas - packs a whollup!
tony barnhill
tony barnhill
No rule on gas but I'm using a stock engine
Bugeye58
Tony, I've always found it helpful to position moveable components with the car on corner scales. Then you can juggle to optimize corner weights.
If you're lucky, and come in underweight, you have the same option when positioning ballast.
Jeff
tony barnhill
tony barnhill
Jeff....if only I had corer weights! I'm looking for some bathroom scales that go up to 500lbs, then I can jury-rig a corner setup.
Nunyas
hmmmmm... even if you can't find scales that go to 500lbs you could still rig up something with that type of scale by using a system of levers. Of course, there'll be a bit of math involved to figure out the length of levers needed to reduce the amount of force applied to the scale and then to translate the amount of force applied to the scale to what the original weight is.
that may require a bit more fabrication than you want to do at this point though... but it could be done with scales that have a lower max wieght.
jlaird
Use two, and put a 2X6 between them?
tony barnhill
tony barnhill
As of this afternoon, the only remaining battery box under the car is only a series of thin angle metal - sides are cut out! Completely!
Hmmm mine looks like that one sounds. I didn't know they had sides on them.
[ QUOTE ]
[/ QUOTE ]
YAY!!! Got my angled ~aluminum~ (1") to remake mine about a week ago... Just waiting for the Round Tuit to show up.
tony barnhill
tony barnhill
Kenny - this is a '68 w/dual batteries - different box than yours....man, it hurt to cut up 2 perfectly good, solid battery boxes!
I'd *almost* want to have the left-overs, but my heart's set on ONE battery, and a bit less to rust later.
Patrick67BJ8 Special Tuning using AF Equipment by Innovative Motorsports Austin Healey 27
jfarris LBC's at Barber Motorsports Park Racing 1
jfarris 24 Hours of Lemons Barber Motorsports Park Racing 2
C Live: Rolex Monterey Motorsports Reunion Austin Healey 6
HealeyRick Earls Court 100M in Classic Motorsports Austin Healey 5
dougie Sonoma Historic Motorsports Festival 2014 Austin Healey 17
Michael Oritt Elva to be featured marque at VRG's 2015 New Jersey Motorsports Park races Racing 1
S Classic Motorsports article on the Sebring Alpine Sunbeam (Rootes) 1
dougie Classic Motorsports SCCA Champ Truimph Racing 4
K Classic Motorsports Magazine Triumph 3
aeronca65t TR6 Grassroots Motorsports TR6 For Sale Triumph 4
M Classic Motorsports Sept Issue Spridgets 5
Twosheds Michael Oritt in Vintage Motorsports Racing 12
BobbyD F40 Motorsports & Chasing Classic Cars in CT Triumph 6
tony barnhill Barber Motorsports Museum British Motorbikes 3
BobbyD Wedge Classic Motorsports & Wedges Triumph 1
S Wedge TR8 Article in Classic Motorsports Triumph 0
Mickey Richaud Wedge Wedges Featured in "Classic Motorsports" Triumph 4
Gearhead South Jersey Motorsports Park Racing 4
John Moore Transmission Swap Article in Classic Motorsports Spridgets 11
Monark192 Team Sprite in Classic Motorsports Magazine Spridgets 10
ChrisS New Jersey Motorsports Park HELP! Racing 1
martx-5 TR2/3/3A Classic Motorsports Article on TR3 Suspension Triumph 2
jlaird Classis Motorsports Spridgets 1
T Classic Motorsports Triumph 5
kennypinkerton I got my first Classic motorsports.... MG 3
tony barnhill 2006 Grassroots Motorsports Kuhmo Challenge MG 8
tony barnhill MOTORSPORTS: GRM Car Springs MG 38
tony barnhill MOTORSPORTS - Exhaust MG 1
tony barnhill MGB MOTORSPORTS - MGB Anti-Sway Bars MG 21
tony barnhill Latest "Classics Motorsports" MG 9
tony barnhill Latest "Classics Motorsports" Spridgets 1
tony barnhill $2006 Grassroots Motorsports Kuhmo Challenge MG 7
tony barnhill Classics Motorsports Midget Up-date Spridgets 2
Simon TR4a Triumphs in Classic Motorsports Triumph 1
MGretired Coveland Motorsports Screen saver MG 1
Bret Classic Motorsports MAG; X-Ray Specs! MG 6
I Imps in Grassroots Motorsports magazine Sunbeam (Rootes) 8
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 7
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
