TR2/3/3A More TR3 Qusstions
oxendine
While I'm on a roll I have a couple more questions. My car was a restoration project underway when I bought it and sure enough lots of little parts are no where to be found. What type of supports were on the bottom of the dash to firewall? There has to be something to steady it. Another is what is the procedure to install the dzus fasteners on the hood? I have the aluminum part that fits on top of the hood, the fastener itself and the deal that bolts to the inner fender. What type of spring holds the fastener itself from falling off?
Thanks, Donnie
martx-5
The dash has two brackets that run from the dash to the firewall. There are four holes in the lip of the dash in groups of two located below where the four gauges are. The brackets extend to the firewall where there are two welded on brackets. The supports are flat on the ends where the mounting holes are, and along the rest of the bracket, there are two u-shaped channels.
Here is one procedure for installing the dzus fastener pieces in the bonnet (hood). There is a washer that is used to hold on the dzus fastener, but it's a PITA to put on and take off. I just used an "E-Clip", and it worked out fine, easy on, easy off. I forget what size it is, but somewhere around 3/8" to 1/2". Take the dzus fastener to you local hardware store and have them give you a couple that fit in the groove.
E-Clips...
lbcs_r_fun
Thanks, Donnie
Donnie: If you don't have one, get yourself a copy of the TR3 spare parts catalog. It's full of diagrams which will answer most questions like this. You can download a free copy. Just Google it.
See example below.
Good luck, T
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
TomMull TR2/3/3A TR3 pushrods; Nothing seems simple any more Triumph 2
M TR2/3/3A One more steering question TR3 Triumph 4
T TR2/3/3A more ? on the TR3 deck lid Triumph 6
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
Tr3aguy TR2/3/3A I wish I had more room,,,,,TR3 Triumph 9
K TR2/3/3A More TR3 SU Rebuild Questions. Triumph 11
N TR2/3/3A TR3 the neverending search for more torque and HP Triumph 4
S TR2/3/3A One more tr3 gas tank? Triumph 1
ekamm TR2/3/3A more tr3 interior questions Triumph 5
K TR2/3/3A More on Spark Plugs for TR3 Triumph 2
K TR2/3/3A TR3 Rear Bush Replace Pic from More BS aboutTR's Triumph 5
K TR2/3/3A More TR3 Trunnion Questions Triumph 4
C TR2/3/3A More TR3 cooling ideas Triumph 4
T TR2/3/3A Once more with feeling, adjusting oil pressure TR3 Triumph 4
Alan_Myers TR2/3/3A TR3 project FS [actually two cars & more: $6750] Triumph 11
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
