Hi guys, and especially Doug. Doug, when you said you had to really wiggle the wishbone arm off I believe you but I can't see how to do it with the bolt orientation this way. Don't I have to take the bracket off at this point, or is there really room to slide the arm out?
Second question - is the red plug normal in the last bolt hole for mounting the spring pan to the arms?
Thanks!
Thanks!
