more basic questions
richrd
I'm trying to educate myself before I "accidentally" buy a project.
What does the word "base" refer to in some of the ebay cars.
Is the mgb gt more desirable than the convertible?
What is the comfortable cruising speed of these little cars?
And finally, are there any big advantages of the triumph or mb over the other?
I have been around British bikes all my life and understand the mindset of the industry back then and I'm guessing it carries over to the cars.
Mickey Richaud
Platinum
Hey, Rich -
"Base"? Not sure, but maybe base model that was offered. Can you give an example?
As for the GT vs. the convertible (or as they were called, "Tourer"), there were fewer GTs built, and they are gaining in favorability. But the Tourers are still bringing more dollars. Boils down to whether or not you want the top down! I'm lucky enough to have both!
Cruising speed will vary, but overdrive will definitely bump that up. These cars never were built to run the interstates.
And as for advantages of TR/MG, that's really subjective. I've enjoyed both; fate had much to do with my ending up with two MGs. I was happy with one of each until the GT happened along.
Try several out for yourself; one will speak to you.
:cheers:
Mickey
aeronca65t
Not sure how "base" is being used. Generally, this would mean a "basic" model with no options (sort of "stripped down"). But most British car are pretty basic anyhow and have few options, so I don't see this being a big deal either way.
MGB-GT might be better if you are in a cooler climate. But these are old cars, so I wouldn't drive either a B or a B-GT on salty roads. The GT can be pretty stuffy in warm weather unless you modify it and install air conditioning (which was a pretty rare option). I have an MGB roadster (convertible) and I really like it. It has a new top and is plenty warm enough in cool days with the top up (especially if you're used to riding bikes). You can also get a fiberglass hard top for the B roadster.
My non-overdrive MGB is good cruising at about 60 mph (but will easily go much faster). The overdrive option probably gives you another 10 mph.
MG vs. Triumph is just like Ford vs Chevy! You have folks on both sides of this.
JPSmit
As mentioned, open top motoring or not is that choice. Beyond that, size -mgb/ mgbgt and tr6/gt6 are bigger and more powerful than Midget/Sprite or Spitfire.
Parts availablity are the same for both, so, unless you have a preference as to style or marque, the real thing to look for is condition. Mechanicals are relatively cheap, interiors not so much and as usual, rust is the enemy.
Don't rush, there are lots out there and not terribly expensive for the most part.
drooartz
Not sure, as these cars really didn't have trim levels like American cars did at the same time. An MGB was pretty much an MGB, just had a small handful of options. Triumphs were pretty much the same.
If you go by the pricing guides, no. Convertibles (of almost any marque) are usually more valuable as, well, the top goes down. Often seen as a big plus in a fun car. That said, the MGB GT is a really nice looking car and would have some advantages in cooler weather. The biggest difference is that the windshield in the GT is a couple inches taller -- so that you've got a bit better visibility when the top is up. That said, I'm really happy with my MGB tourer, the top works well (at least to keep warm) and it is nice to be able to go top-down.
My stock MGB with factory overdrive can easily cruise at 70mph all day (I've done it). I've no issues with freeway driving -- the overdrive makes a big difference here.
They're both great marques. I've had both, and there are plusses and minuses to each. I'm a reasonably big guy (6'1", 210#, big feet) and I find the MGB roomier than the Triumphs (talking TR3 and TR4 here). They made 500,000 MGBs, so they also tend to be cheaper to buy. Running costs and parts availability is similar, though the MGB is probably one of the best supplied classic cars in existence.
Triumph engines, if all stock, tend to be a bit more powerful. Both can be modified for more power with plentiful options.
To sum up, it's pretty much down to what makes you happy. Can't go wrong either way. Find the one that draws you in and go. These are simple and robust little cars, some of the best fun-to-cost values in the classic car hobby.
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
maxwedge5281 one more time.....mirrors! Austin Healey 14
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Drone Dog BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
K TR2/3/3A More electrical....the Starter? Triumph 5
S TR4/4A More restoration questions Triumph 8
K TR2/3/3A One more Steering Box question. Triumph 2
catfood Must have a little more faith in my system... Austin Healey 4
tinman58 TR6 More transmission questions Triumph 3
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
W But wait, there's more...... Spridgets 12
K TR2/3/3A More on setting the timing... Triumph 12
K TR2/3/3A More electrical....parking lights?... Triumph 2
K TR2/3/3A More wiring confusion re: diagram? Triumph 5
Tinkerman TR2/3/3A 1960 TR3 A More body panel assembly questions. Triumph 5
Healey Nut more Healeys in video Austin Healey 0
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
TomMull GT6 More on value trends Triumph 12
K TR2/3/3A More wiring questions? Triumph 5
