GeorgiaTriumph
Could someone please list the parts that need to be swapped for a mk2 clutch changeover on a mk1. Ive done the fly, 3pc clutch, bearing carrier, and repro slave. Only problem was that it wouldn't work. I had to put the original slave back in and it will work but with about an inch of pedal travel. Very unsatisfactory. Could it be a bad repro slave? Is it worth buying the oem? Thanks for the help.
