Midget - New Carb?
Midget Larry
Boys, I have a 1974 Midget, with the 1275 engine. It has an old Weber carb that has been a real headache, and I am thinking maybe I should just start fresh with a new carb. (1) What's the expert suggestion(s) for a new carb on this engine, (2) where's the best place to get it, (3) how hard is it to replace, and (4) what special considerations are in order for the fact that my garage is at 6,200 ft. elevation, and I drive every day to about 5,300 ft.
tony barnhill
Great Pumpkin - R.I.P
Nothing wrong with the original carbs when set up properly!
Dr_EluSivE
Su's
Personally i would rebuild the weber and go. i rebuilt my su's multiple times and my car never ran as good as it does now with the weber. Best MG investment yet!
Dr.
[ 09-18-2003: Message edited by: Dr_EluSivE ]</p>
Baxter
Gee, I've never known a Weber to give problems. Once they're set up, they just go, and go and go.
What kind of Weber? What kind of problems?
Most carb problems are in the ignition.
Tom Bedenbaugh
There's not a lot that could wear out on a Weber. If the throttle shafts are tight you should be able to just rebuild it. What kind of problems are you having?
William
The only suggestion I'd make is to check if the Weber fitted to your car is actually one that would normally be offered in one of the Weber conversion kits from Moss, VB, or wherever. If it's okay, rebuilding it is a nice winter project. Much as I like SUs, I see no need to replace the Weber if it's correct and maybe needs new jets and whatnot.
-William
M
Midget Larry
Well, there seems to be unanimous sentiment for rebuilding the old Weber. The problems I have encountered are "drop out" of the idle (no idle), progressively racing idle (as the car warms up, going from 800 to 1500) and excess fuel (constant smell of fuel coming from the carb), but I guess these problems may be solved with float/jet and rebuild treatment. Thanks for all the input, you Wever conservationists.
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
doc50 73 Midget Carb linkage confusion Spridgets 5
DrEntropy For Sale Midget/Sprite carb set Spridgets Classified 0
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
E 1977 Midget Weber carb FORUM Help 0
E 1977 Midget Weber carb Spridgets 1
bcbug 1500 midget carb replacement Spridgets 38
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
M 79 midget carb question Spridgets 11
tony barnhill MkI Midget Carb Linkage Question Spridgets 27
Steve P. '78 Midget carb heat shield? Spridgets 1
NYMidget Midget carb upgrade Spridgets 5
R 1500 mg midget, weber dgv carb & affect on timing Spridgets 9
P midget holding back/ carb problem? Spridgets 1
Y Weber carb conversion, Midget 1500 Spridgets 21
G Carb Insulating Block on 1500cc Midget Spridgets 5
jaybird Midget carb question MG 0
G 79 Midget Clutch issues Spridgets 3
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 4
O Ignition switch / steering lock replacement in a '78 midget Spridgets 4
M Midget runs inconsistently Spridgets 7
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
BJ8Healeys Cigar lighter for '73 MG Midget MG Classifieds 4
Gearhead Midget parts for sale Spridgets Classified 0
Gearhead Midget seats for sale Spridgets Classified 0
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
JPSmit Electric Midget Spridgets 1
skystryd Idea Time 79 Midget Spridgets 2
BJ8Healeys For Sale Midget/Sprite nose section - used [Moss Motors P/N 455-145] Spridgets Classified 0
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
M General MG Midget MK1 windshield replacement MG 2
D For Sale MG Midget for sale Spridgets Classified 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
K Midget Brake Pedal Question Spridgets 2
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
S For Sale MG Midget Parts Garage Clearance MG Classifieds 0
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only Spridgets Classified 0
Mick2me For Sale Various MG Midget/Austin Healy Sprite parts for sale [approx 1964] UK only MG Classifieds 0
A 76 Midget 1500 Oil filter Spridgets 6
AngliaGT At a Local Car Dealer - Midget Spotted 7
JPSmit '74 Midget Spotted 1
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
