T-Series MGTF "Upgrades"
BillBaker
MGTF "Upgrades"
Have owned my TF for 35 years. "Restored" it in 1967, and now needs a total ground up. Recently retired so getting ready to do it right this time.
Did a Moss 4.55 conversion with the help of the Southeast Register in Atlanta.
My question is: does anyone know of a list of those neat "upgrades" that have been developed through the years, ie. neg grd, clutch linkage improvement, use of MGB radiator fan, etc. I would like to incorporate them this time around.
Thanks,
BB
Gary Lloyd
Re: MGTF "Upgrades"
Just a thought, but if you change it from original, would it lose value?? But then again, is the drivability worth it? Somebody that knows more than me will come along soon!!
William
Re: MGTF "Upgrades"
I suppose the question of originality is there, but two things to consider are: is the car going to be shown at concourse events, where originality and having all the screw heads lined up a major issue? Also, are modifications reversible? IE-using an MGB fan with more blades might be sensible, as it's comparitavely easy to put the old fan back on. Same with free flow air filters, bolt on performance widgets (up to and including superchargers, I suppose), and even custom upholstery. Think twice about molding in the fenders or frenching the headlights, though.
In many cases, sensible period (or period styled) upgrades can enhance the value of a car. Factory performance upgrades like stage two tuning kits are always desirable. Cutting up a perfectly good chassis and firewall to slot in a small block Chevy for extra passing lane power may not. YMMV
-William
kmcormick9
Re: MGTF "Upgrades"
believe it or not my friends father is in the process of restoring a td (what year is beyond me) and along the restoration he is fitting it with a small block chevy engine. he also has a chrome bumper b that he has molded the headlight bumps into the hood and the new headlight placement is in the grille. we call him the isemann coachworks
kmcormick9
Re: MGTF "Upgrades"
ill try and get one. just so you know its not quite finished....in primer....no interior. but the grunt work is done.
John S Farrington
Re: MGTF "Upgrades"
Changes to the coachwork exterior and interior trim and dash instruments should be avoided. For driveability and reliability, I would recommend a replacement alternator,(self contained regulator) and a solid state ignition system for a start. A later model Lucas alternator and a Pektronic ignition system would be one of the easier ways to go about this but there are several choices. Unless the TF has had a cooling problem I would not add electric cooling fans. If you want to do this then the alternator swapis mandatory. Best regards,
MGTF1250Dave
Re: MGTF "Upgrades"
Aloha Bill,
I'm an gathering parts to repair/rebuild the body tub on my TF. I also have a MGA rearend that I'm planning to use as parts to lower the rearend ratio to 4.3. I'd be interested in hearing from you how your change in ratio worked out.
Depending on how far you intend to dismantle the car here are some things I would suggest you consider.
1 Rebuild the cylinder head for unleaded fuel with stellite valves.
2 Replace the front and rear crankshaft seals with modern lip seals (Moss has these).
3 Convert to a spin on oil filter with a back flow preventer. This gives instant oil pressure on engine start up by keeping upper engine oil from draining to the oil pan when the engine is not running.
4 Replace suspensions bushings with polyurethane bushings. These do not deform or perish like the rubber ones.
5
MGTF1250Dave
Re: MGTF "Upgrades"
My fat finger sent a reply before I was done.
5 Add a front sway bar if you don't have one.
6 Convert to radial tires if you have not already. the greatly inprove handling and the ride. A meteric radial 165R15 is a very close match to a bia ply 6.00 x 15 tire.
7 Have the radiator boiled out and tested. If necessary have it recored. The original radiator and fan should be more than capable of keeping the engine cool.
8 Replace the exhaust system with a stainless steel system.
9 Use heat sheild material under the carpets on the floor boards, front bulkhead and gearbox tunnel. This will keep you a little cooler and reduce some noise.
All these keep the car very original.
If you need a new gearbox, you might also consider a 5 speed gearbox conversion. These are available, but cost about $2500 to $3000 for the kit.
Good luck and let us know what you decide.
Safety Fast,
Dave
B
BillBaker
Re: MGTF "Upgrades"
Dave, thanks for the reply. I'm with you on your items 1,2,4,6,7,8,9. #3 I bought a spin on oil filter adapter from Moss, does it have the back flow preventer in it? #5 Sway bar, haven't heard about this one, do you have any details on it?
The ring and pinion conversion went well, but it's not an easy process. Removing and replacing the bearing races can be difficult. And the placment of the pinion gear came down to a trial and error process of .0001 shim stock. I'm sure it will be worth the effort though.
I have an improvement to the clutch linkage, (provides a smoother and better fill to the pedal) no major physical changes required, if you are interested.
Also, do you have a pattern for a TF heat shield between the carbs and manifold. It's hot here in Florida and I need to prvent vapor lock as much as possible.
Thanks again for your great advise.
Bill
MGTF1250Dave
Re: MGTF "Upgrades"
Aloha Bill,
I should have explained further that the back flow preventer is in the spin on filter. I am using a Fram 3600. If you can see a black rubber diaphram through the slots as you look at the bottom of the filter that is the back flow preventer.
The sway bar I have came with my car when I bought it back in '72. Abindon Spares at www.abindonspares.com have one in their tools and accessories section.
I lived in Jacksonville '76 & '77 and it does get hotter their than here in Hawaii. I do not have a heat sheild for the carbs, however I have used an heat sheild material over my neoprene fuel line in the engine compartment. I bought it from J C Whitney, but you can probably get it from any autp parts store. If you still have the long float bowl overflow pipes, this can be cause of vapor lock. The tend to get blocked at the end with road grime, not allowing the bowl to vent properly. I cut mine of about level with the bottom of the bowl and haven't had a vapor lock problem since.
I would appreciate details about the clutch linkage improvements.
Another minor thing, Halogen headlights and tail lights are brighter than the standard ones.
Safety Fast,
Dave
B
BillBaker
Re: MGTF "Upgrades"
Thanks for the additional info. For the clutch linkage info go to oconnorclassics.com/MISC/tclutch.htm
Bill
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
mgbmedic T-Series Return to Forum / MGTF Restoration MG 6
JPSmit Mgtf Spotted 1
C T-Series Stuck exhaust valve on 54 MGTF MG 10
C T-Series 1954 MGTF [not the new TF] gearbox MG 4
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
F T-Series Looking at a 1955 MGTF today- what's important? MG 8
Magyar T-Series MGTF Windshield MG 6
Magyar T-Series MGTF Dark Red Engine Paint MG 7
T T-Series Need Advice - MGTF Steel Wheels Need Attention MG 2
T T-Series Need advice re MGTF rack and pinion removal MG 4
PAUL161 T-Series Victor MGTF [Sebarnes] MG 0
S T-Series Victor MGTF MG 17
CCURTISS T-Series MGTF Lower A-Arm Busing Replacement MG 1
CCURTISS T-Series MGTF 1500 Cooling Fluid Leak MG 6
CCURTISS T-Series Moss 5 Speed in MGTF Complete!!! MG 2
CCURTISS T-Series MGTF Firewall [what goes in what hole] MG 2
CCURTISS T-Series MGTF Carburetor Size MG 1
CCURTISS T-Series MGTF Flywheel and Pressure Plate Torque??? MG 2
CCURTISS T-Series MGTF 5 Speed Conversion MG 3
CCURTISS T-Series MGTF Shifter Rattle??? MG 4
C T-Series Nanjing MGTF MG 15
drjimwbrown T-Series Wonderful drive in MGTF down the Jersey Shore MG 5
swift6 T-Series Fun Hot Rod MGTF... MG 4
Bret T-Series Sighting MGTF in San Diego CA. MG 3
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
T Tasteful Upgrades for a Bugeye [part II] Spridgets 5
T Tasteful Upgrades for a Bugeye Spridgets 8
JimLaney Sprite MK III upgrades - recommendations? Spridgets 23
F For Sale suspension upgrades TR6 Triumph Classifieds 0
T Tasteful upgrades for a BJ7 Austin Healey 21
T Thoughtful upgrades for a BE Spridgets 24
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
Scotsman GT6 GT6 early vs later model differences / upgrades Triumph 13
Morris Brake upgrades? Spridgets 20
simon1966 Period Upgrades? Austin Healey 12
N I need help: What are good Upgrades for my MKII BT7 Austin Healey 13
glemon TR4/4A TR4-6 Steering Upgrades Triumph 15
C TR2/3/3A TR3 Best Upgrades Triumph 21
BobbyD Latest Upgrades: VTO Wheels & Wilwood Calipers Triumph 7
L Good upgrades to a stock BJ8 Austin Healey 55
T Collapsible steering columns & Healeys & upgrades Austin Healey 14
T windshield wiper mods/upgrades? Austin Healey 4
Kirk_Fisher TR4/4A TR4 handling/suspension upgrades Triumph 19
RJS TR4/4A TR4A Cooling Fan Upgrades - Non Electric Triumph 5
T Bug-Eye rebuild & upgrades - advice requested Spridgets 2
Tim_Creger Electrical upgrades for a '52 XK120 Jaguar 10
J upgrades? Austin Healey 19
R Cooling Upgrades TVR 0
HealeyPassion My BJ7 suspension upgrades Austin Healey 13
