MGB MGB Head Mods
kyreb1862
Well I recently discovered I had a small coolant leak in my cylinder head above the number 2 spark plug. For the time being I'm going to use a little sealant to get me by. I know that I am going to have to replace the head eventually so my question is, what mods would be the best to make to my new head to get improved horse power?
Platinum
I'll reiterate what I posted in DieselBrad's post: "The Special Tuning Manual" and books by Clive Trickey and David Vizard are great for info on reworking and tweaking the engines.
Reprofiling the 'squish points', cleaning up the inlet and exhaust runners, "cc'ing" the chambers and port matching are of most benefit in my experience. Makes them noticeably smoother running and boosts output.
Bob Claffie
Why a new head? This leak could be as simple as a bad gasket or a warped head or block. The head could be cured with a surfacing operation of a few thousanths. The block fix would be much more $ and time. Only look at replacement if cracked. Why is everybody so quick to spend big $$$? Bob
kyreb1862
kyreb1862
It actually is a crack Bob. Its located about 2 inches above the No. 2 plug. I wish there was an easy way to fix it because the engine runs great. believe me when I tell you I'm not one to run out and spend big $$$ for no reason, that stuff is just to hard to come by. /ubbthreads/images/graemlins/grin.gif
AlanT
Remove the valve cover and clean the head and you will see the crack from the valve guide to the spark plug hole. FWIW , I've run one like that for six to eight years. Obviously look for an uncracked head to modify.
Alan T
kyreb1862
kyreb1862
[ QUOTE ]
Alan T
[/ QUOTE ]
What have you done to your head to stop the coolant leak to the outside?
kyreb1862
kyreb1862
I'll try it. The leak is not that bad yet, just shows up under pressure. Thanks
Platinum
The K&W stuff is usually pretty effective. I took from your first post that the leak was coming from a cracked head, seen plenty with just what you (and now AlanT) have. If it doesn't get an "overheat treatment" it can last quite a while. Just monitor the coolant level and the gauge.
The stuff I suggested is NOT expensive, and most of it can be done with "hand tools" and patience (with guidance from Visard's book). Good used heads are still around at reasonable cost, too. With the proper drifts you can even replace the guides yourself as well. The only expense would be having a machine shop cut three-angle seats.
kyreb1862
kyreb1862
I couldn't find the K&W stuff so I got some made by Prestone instead. It was successful. Now I no longer have the leak. Thanks for all the input guys. Merry Christmas! /ubbthreads/images/graemlins/thumbsup.gif
jlaird
I ran a plymouth with a leak many years with that stuff in it. No problems.
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
6 MGB 79 MGB Head Gasket Screwup MG 7
G MGB MGB Port and polished head MG 3
B MGB MGB head info. MG 12
bcliff MGB MGB Head Interchange MG 4
R MGB MGB Speedo Head MG 5
J MGB HEAD [MGB ?] MG 32
LeeMcKee MGB Port and Polish MGB head MG 17
W MGB MGB Cylinder Head MG 3
703MGB MGB MGB Head being redone MG 10
T MGB Port/Polish MGB head MG 0
Mickey Richaud MGB Oil to Head - MGB MG 5
Steve P. MGB MGB;blown head gasket...where? MG 1
J MGB MGB Info... In over my head? MG 4
A Wanted 1970 MGB - Emissions Parts MG Classifieds 2
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
