R
Rick D
Hello people;
I'm about to take the MGA in for a wheel alignment, and, truth be told, I don't trust handing it over to some generic front-end alignment shop to be worked on by someone who's unfamiliar with the car. For all I know, I could do it myself, but either way I need some info/confirmation on some things. Thanks. First off, I've been told that the caster/camber adjustment question on the MGA is unneccesary and dangerous to mess with or implement. Secondly, I've also heard that, although the manual calls for a parallel setup, that is, no toe-in or toe-out, the spec was meant to address the original setup (bias-ply tires), and that with today's radial ply tires taken into account, there should be a slight toe-in (1/16 inch maybe?) Let me know what you think, and thanks..
