MG Midget Heat Shield
tony barnhill
Great Pumpkin - R.I.P
Jack Laird pointed out that on page 59 of "The Original Sprite & Midget" there's a photo of the engine compartment of an AH MkII/ Midget MkI engine & the heat shield is painted engine color.
Now, the valve cover says "AUSTIN" & that's a photo of a 948 engine & mine is the later MkI with a 1098 engine....but, page 81 also shows a painted heat shield on an "AUSTIN" engine....
Anybody got an original MkI Midget with a painted heat shield?
John Moore
A friend of mine up here has a concurs '65 Midget. This guy is OVERLY meticulas and even contacted Terry Horler to help him with the detail. His heat shield is engine color.
jlaird
Dear Tony,
Another bit of info. That darn heat sheild is tough to get paint to stick to. Sand blast it and prep properly.
Jack
tony barnhill
tony barnhill
Okay! Tomorrow I sandblast a brand new heat shield & put high heat primer on it before painting it engine color!
jlaird
There ya go Tony. I will do mine the same way when I pull the engine this fall.
Whitephrog
The concours guy's Originality Guide says that the carburetor heat shield was painted the same color as the engine on all models.
jlaird
There ya go. The final answer.
Thanks Ray.
tony barnhill
tony barnhill
Ray - is that guide for MG's as well as Spridgets?
GeeBee1
I thought that some of the later 1275's were black.
jlaird
Same as engine color, if you engine is supose to be orange or black then the heat sheild is the same.
GeeBee1
Jack:
What if my engine has cow spots on it :shocked:
jlaird
:nonono:
bugimike
GeeBee1 said:
Jack:
You will have to quit "off-roadin'" across cow pastures!!! :jester:
JPSmit
GeeBee1 said:
Jack:
that would be a different kind of hybrid - Oh, not THOSE cow spots
Whitephrog
Tony
The guide is published by the Austin Healey Concours Registry and applies to Sprites.
tony barnhill
tony barnhill
That's what I thought...& there are differences between Sprites & Midgets that go beyond the marque differences...some of them are how the Midget was assembled differently than the Sprite (some things on the Sprite were painted but the same thing on the Midget wasn't - for example).
Steve P. '78 Midget carb heat shield? Spridgets 1
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
