MG Midget 1500 Flywheel
blkcorvair
Does anyone have a picture of a stock midget 1500 flywheel they could post. Im trying to compare to a modified one that I have. Thanks.
(Cross posted in Triumph. May get one there?)
dklawson
Scott, take a look at the following three pictures:
https://home.mindspring.com/~purlawson/pictures/72Spit/1300 FW Front01.jpg
https://home.mindspring.com/~purlawson/pictures/72Spit/1500 FW Back01.jpg
https://home.mindspring.com/~purlawson/pictures/72Spit/1500 FW Front01.jpg
The 1300 flywheel has a largely flat surface with only a slight raised surface where the pressure plate bolts. That surface is also the surface where the friction disk sits. (Please excuse the rust... we had some driving rain that splashed up from underneath the car).
The 1500 flywheel has a raised ring where the pressure plate sits. The friction disk sits in a recess below that surface.
I hope you see in these pictures what you were looking for.
EDIT: Sorry... I don't seem to be able to create dynamic links to the pictures. You'll have to cut and paste the address to a new browser window.
dklawson
Hey... I came back to post an eBay link for you... but it looks like it's your auction! Good luck and I hope the pictures did help.
BTW, I assume your handle here means that you also like Corvairs. I have a couple of friends who are into 'vairs. While at Toys-R-Us I bought one of them a diecast '63 convertible from the Johnny Lightning collection. This year's collection from them is pretty neat.
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 0
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
J 1500 mg midget fuel issue Spridgets 2
J 1500 midget master cylinder Spridgets 10
T ZS Question for 76 1500 midget Spridgets 33
T 76 midget 1500 oil pressure lines? Spridgets 15
frankenstang57 Educate me on the Midget 1500 MG 4
R Overdrive/5 speed options for 1500 Midget? Spridgets 15
P how to replace rear main seal in 1500 midget Spridgets 2
R pcv valve for 1500 midget? Spridgets 12
R spark plug for a 9:1 ratio 1500 midget? Spridgets 5
T 76 midget 1500 engine crud Spridgets 4
RickB Seat recovering, 1500 Midget Spridgets 18
R 1500 midget clutch inspection? Spridgets 3
R oil feed kit for 1500 midget? negatives in this? Spridgets 5
Rhodyspit75 Spitfire Midget carbs and manifold on 1500 Spit Triumph 6
D Vacuum unit for 1500 Midget Spridgets 7
P holes in 76 midget 1500 front bumper Spridgets 6
R compression test procedure on 1500 midget Spridgets 5
G 79 midget 1500 clutch? Spridgets 5
A MIDGET 76 1500 CLUTCH SLAVE CYLINDER Spridgets 1
bcbug Midget 1500 Hose Connections Spridgets 9
RickB Midget 1500 dual circuit Master Cylinder troubles Spridgets 7
7 79 midget 1500 Emission Removal Spridgets 3
G 79 mg midget 1500 wiring Spridgets 7
bcbug 1500 midget carb replacement Spridgets 38
A 1300 cam bearings in Midget 1500 Spridgets 3
M 78 1500 Midget Tire Sizes Spridgets 1
J Midget 1500 electronic ignition? Spridgets 10
S 1500 Midget air intake Spridgets 1
S 77 Midget 1500 gearbox Spridgets 4
boxfullofyertoys Midget 1500 idle problem MG 0
boxfullofyertoys Midget 1500 idle problem Spridgets 10
tony barnhill Patriot 1500 Midget Headers Spridgets 3
R k&n air filter p/n for weber dgv on 1500 midget? Spridgets 7
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
M Weber DGV Carb Conversion for 78 MG Midget 1500 MG 0
M Weber DGV Carb Conversion for 78 MG Midget 1500 Spridgets 26
c5racer Spitfire 1500 Spit exhaust manifold fit a 1500 midget? Triumph 2
B Midget 1500 Waterpump Pulley Spridgets 0
Steve P. 1500 Midget; sticking choke Spridgets 6
P Midget 1500 starts when cold; doesn't when warm Spridgets 9
