Master Cylinder... Expensive?
BLG
I have been doing a bit of research, and it seems as if a brake master cylinder for a 64 Midget is quite expensive, if one can be found.
I found a couple and they were about $250.00 to $500.00!
Is this normal or am I looking in the wrong places?
vping
Bronze
Why not rebuild?
tony barnhill
Great Pumpkin - R.I.P
948 MC's are quite expensive, 1098 MC's are hard to find
I'd second rebuild if its not too pitted.
Keoke
Send it to White Post Restorations in White Post Virginia. Call and get an estimated price to Sleeve and rebuild.--Fwiw--Keoke
John Loftus
Since you are in California you might consider Sierra Specialty Automotive who specialize in resleeving cylinders. I had them do my Healey masters, wheel and slave cylinders and was very pleased with the workmanship, price. Also good to know they should never wear out unlike the stock cylinder material.
https://www.brakecylinder.com/
Cheers,
John
Phantomracer
I must be the only one in the buy new camp. Just my expereience that every rebuilt MC I have had installed, in any car I have owned, leaked sometime after installation prematurely.
My mechanic LOVES rebuilt MC and shocks (customer supplied)..just means he gets to do the job over and over and charge the customer each time!
No doubt there are good rebuilds out there. I just must be missing them!
John Loftus
No doubt there are good rebuilds out there. I just must bemissing them!
Re-sleeving (done properly) makes them better than new. The sleeve materials used resist corrosion and wear much better than the stock material. A simple rebuild (hone and new rubber bits) will not last too long because you have removed any hard anodizing and material. The surface will pit sooner and is rougher so the rubber bits wear faster. Anyway, big difference between "rebuild" and "resleeve".
The place I used says this, "You end up with new looking parts that will last indefinitely because the cylinder bores are now non-rusting, non-corroding brass instead of iron or aluminum. We are so sure of this that we offer a ten year guarantee against defects in materials and workmanship. This guarantee transfers to the new owner if you sell your vehicle."
As far as rebuilt shocks. The ones done by World Wide Auto of Madison are guaranteed for life not to leak again. Peter rebuilds them with seals that are better than new.
Cheers,
John
L Removing Master Cylinder Without Paint Damage Austin Healey 27
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
6 Master Cylinder Actuator rods Spridgets 2
6 Master Cylinder Install Spridgets 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
R TR2/3/3A Master Cylinder Re-build Triumph 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
D TR2/3/3A sealing master cylinder pocket Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
R TR2/3/3A Lockeed Master Cylinder Adapters Triumph 8
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
D Clutch Master Cylinder Leak Austin Healey 20
6 Master Cylinder Rebuild Help Please Spridgets 3
D BJ8 brake master cylinder question Austin Healey 6
Lin Master cylinder packing pieces [shims] Austin Healey 29
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
F Austin Healey Sprite MK I - master cylinder cap Austin Healey 1
D TR2/3/3A Brake Master Cylinder. Triumph 4
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
Michael Oritt Brake Master Cylinder access Austin Healey 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
bugedd Master Cylinder Question Spridgets 7
S Smitty trans Master cylinder Austin Healey 21
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
nevets Master Cylinder question Austin Healey 8
JimLaney Sprite MK III combined master cylinder issue Spridgets 10
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
