master cylinder bleed kit
jerrybny
Does anyone have any suggestions on where to get a master cylinder bleed kit? I need to replace the master cylinder on my 73 TR6 and want to bench bleed it before installing it.
Jerry - Have you tried NAPA? I picked up a generic bleed kit at a local auto parts store a number of years ago. It just consists of a couple of plastic fittings that screw into the ports and a bit of hose with a clip to hold them in place in the filler neck of the M/C. You then just pump the fluid out and in the M/C until the bubbles go away.
Cheers,
