Mallory Unilite Distributor
RyanH
I recently purchased a mallory unilite distributor to replace my stock distributor on my 1979 MGB. I'm having difficulty installing it with a new drive dog. It doesn't want to fully seat. Has anyone had similar difficulty?
G
did you install the drive dog yourself? is it maybe too long? can you compare it to a Lucas unit?
R
RyanH
Hi Chuck, thanks for the quick reply. To answer your questions...yes, I installed the new drive dog myself. Everything seems to match up fine, checked the dimensions and visually looks the same. The old drive dog looks a bit worn. I can install the old distributor with no problem. The only thing I can think of now is that maybe the retaining pin for the drive dog is too long. I tapped it through the shaft and there's just a hair protruding on either side. I'll try to file down and see if that helps.
Ryan
R
RyanH
Got it...I engaged the drive dog, tapped it in with a hammer until fully seated, then pulled the distributor out. The gouges on the drive dog showed me exactly where I needed to grind it down.
Ryan
GTsRFine
Is that Unilite with or without vacuum advance? If it's advance mechanism is centrifugal only, then you have a total of about 26 degrees advance
B Mallory Unilite Restoration & Tools 1
M Mallory Dual point distributor Austin Healey 0
W Mallory distributor on '60 BT-7 Austin Healey 4
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
D Experience with Mallory twin point distributor. Austin Healey 5
B Mallory Dual Point gap Austin Healey 4
Jim_Stevens TR2/3/3A Distributor clamp with a Mallory? Triumph 5
aeronca65t A35 Race Mallory Park-UK-2015 Racing 7
C Mallory dual point recurve help needed Austin Healey 6
memphis Mallory Distributor Austin Healey 0
memphis Pertronix & Mallory Dual Point [Positive] Austin Healey 11
D pertronix for mallory dual point Triumph 5
6 Mallory Coil/Pertronix Q? Austin Healey 5
A Mallory Dual Point Dist MG 6
T Mallory ignition Triumph 14
DNK Mallory help Triumph 0
T Mallory optical distributor Triumph 32
specialsports Mallory Dizzy Other British Cars 10
A 123 Ignition vs. Mallory Austin Healey 28
M Mallory Distributor Austin Healey 26
SCguy Mallory Unlite Distributor wiring Triumph 12
tontonene Mallory Dual Point Distributor Austin Healey 25
PeterK What coil to use for Mallory 2332001 Triumph 11
RSMTR8 Wedge TR8 Mallory Distributor Triumph 6
B TR2/3/3A TR3 Pertronix conversion for Mallory Dual Point Triumph 18
G TR6 TR6 Mallory Dist Triumph 10
C Mallory dual point settings Triumph 1
JFS TR6 TR6 Unilite Triumph 8
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
