Lucas starter motor field assembly
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
My field toasted itself a couple of years ago.
I was able to locate (locally) a starter that ended up being new or freshely rebuilt, and it has functioned fine.
However, being a Jaguar and Lucas, I am looking to fix this one for a "spare".
I have the field pieces out, and the windings out.
The insulation on at least one field piece has gone....whether age, or the ensuing smoke and heat is unknown.
I do know that a 3M product called Varnished Cambric works, for heat and insulation properties, but no-one local seems to have it.
Anybody know where I can get a field piece re-insulated?
Or find some of this Cambric?
Marvin Gruber
Take the fields to a local electric motor repair shop. They can rewind it. If you think the field piece is not shorted, buy a spray of black Glytal insulating paint. Spray it(hose it down)with the paint several times and put it back together. We used Glytal in repairing large electrical motors and generators.
Marv
Deleted member 8987
Hmm.
Glyptal will hold up?
That will hold on the flat barstock field winding?
Marvin Gruber
We used Glytal to reinsulate generator windings in all the power plants. Spray it heavy on the copper and let it sink down into the windings. Do several coats. Red or black, doesn't matter For a barrier between the copper and stator housing, go to the Electrial motor rewind shop and ask for 1/16" insulating sheet. They have many types. Ask for class H insulation. You could also use a piece of gasket material, spray both sides and use that as a barrier between windings and stator.
If you can find cloth tape, half lap wrap the windings and spray it down with the glytal, you won't need the insulation sheet then. As far as the barstock, just wipe the top of the steel off after you paint the windings. You want the paint to weep down the sides of the metal.
Marv
H BJ7 Starter Motor, Lucas 25550 Austin Healey 1
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
TulsaFred Lucas starter Spridgets 8
J lucas starter wire MG 1
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Help 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
A TR4/4A Lucas parts Triumph 7
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
K Data on Lucas 78366 Rheostat? Other British Cars 0
Healey Nut Lucas wire bullets Austin Healey 38
C TR4/4A Interesting Lucas lighting issue??? Triumph 5
JimTR4 TR4/4A Rear mounted Lucas WLR 576 lamps Triumph 3
Jeepster Lucas RB340 Austin Healey 3
F TR2/3/3A C39 Lucas Generator Triumph 4
Michael Oritt The Scourge of Lucas Austin Healey 2
HealeyRick General TR A Lucas Christmas Triumph 1
toysrrus TR2/3/3A Lucas "Driving / Fog" Lens wanted: Triumph 9
HealeyRick It's Not Just Lucas Starters Austin Healey 2
T General Tech Lucas? Triumph 3
