Lucas Sport Coil
PeterB
My stock coil had sw & cb terminals my new lucas sport coil has + & - terminals can someone help me and tell me how they correspond.
Thanks,
Pete
reddsprite
"SW" = "-" and "CB" = "+". "SW" is switch,"CB" is contact breaker
In the positive earth system the ignition switch supplies power from the Negative battery post, and the contact points ground the other side of the coil to the Positive battery post. Therefore "SW" = "-" and "CB" = "+". This bit of knowledge and logic can avoid confusion if you change your vehicle from positive earth to negative earth. In that case you reverse the coil wires, and the "CB" terminal connects to the positive Switch wire while the "SW" terminal gets grounded to negative through the Contact Breaker.
S Intermotor or Lucas Sport Coil ? Austin Healey 14
Lin Chrome Lucas Sport Coil? Austin Healey 9
S Lucas Sport ignition coil Triumph 29
drambuie Exploding lucas sport coil Austin Healey 33
Jim_Newman Lucas Sport coil Austin Healey 2
T Lucas Sport coil question Triumph 21
kyreb1862 Hooking Up A Lucas Sport Coil MG 6
kyreb1862 MGB MGB Lucas Sport Coil MG 1
kyreb1862 Lucas Sport Coil MG 20
Brosky Is the Lucas Sport coil worth the effort? Triumph 4
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
jmayled Lucas Sport Coil Installation Triumph 16
D Lucas Sport coil / Pertronix ignitor MG 9
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
