Camshaft
Hello gents, I have some money to complete some winter projects, and I intend to lower the MGB, install the '78 sway bar, and give her just a tic of toe-in and negaive camber. These are what I plan on ordering later this week. Am I forgetting anything? Should I make any changes?
480 lb./in. springs 264-385
Rear spring lowering kit 264-140
Rear spring pad set 281-600
Rebound straps 267-565
Shortened bump stops 266-590
Negative camber wishbone arm set 264-038
Polyurethane A-Arm bushings 280-485
Link, RH, sway bar 264-840
Link, LH, sway bar 264-830
