if you look at the attached, you will see the pieces that make up my throttle mechanism at the Carb.
https://tinyurl.com/6kgsa8
"C" is what attaches to the carb itself - the bottom of that bracket is broken.
"A" attaches to "B". If you zoom the photo you can just see a ball fitting. There is a press on fitting that "A" actually bolts to.
"D" is the remains of that press on fitting.
Here are my questions
#1. Can I replace "D" and "C" and therefore fix the mechanism?
if no
#2. Does someone else have another throttle mechanism they want to sell? Mine seems overly complicated, perhaps because of the pollution or the water choke - neither of which are attached any longer.
or
#3. Is this the sort of thing I could find at NAPA?
thanks all
if no
or
thanks all
