TR6 Looking for tips on folding soft top TR6
2wrench
Got a soft top installed. Any tips/advice on folding
the thing down?
I have a zippered window in the top.
Thanks,
2wrench
pa297pass
Re: Tips on folding soft top TR6
I'll try 2wrench.
1. Unsnap the 3 or 4 snaps on each side behind the doors.
2. Unattach the top from the frame above the side windows (mine has velcro).
3. Some tops have snaps inside to the center top bow (mine doesn't) - unattach this.
4. Unlatch the top from the windshield frame (probably should be #1)
5. Once the cloth part of the top is loose from the frame, start folding the frame down with one hand while holdng the cloth out of the way. You want to end up with the top frame stowed and the cloth all laid out over the trunk.
6. Fold the "sides" of the laid out top toward the center of the car along the split between the side and rear window (try not to fold across the "glass)
7. Fold the rear most part of this laid out / folded top forward and tuck it down behind the seats.
8. Install the "cover" over the folded up top and snap it to both the outside of the car and to the rear interior panel to support the folded up top off the shelf behind the rear seat.
Whew ... that was way harder to type up than to do. This is how I fold mine, and my rear window (also zip in) still looks like it did 17 years ago.
Hope this helps and good luck.
Matt
pa297pass
Oh, BTW, that is on my TR6.
Matt
Edit: Oh, maybe I should have read the title ... /bcforum/images/%%GRAEMLIN_URL%%/crazy.gif
G
All good advice. The big thing is not to get the top folded in such a way that any part of the frame gets it into a scissor-effect pinch. Guaranteed to cut your brand new top. I made the fatal mistake of lending my car to my middle son a few years ago to take his girlfriend for a spin. He thought it cool to drop the top somewhere in the middle of the ride to catch some wind and impress the girl. Came back with a nice cut in a brand new top. I have since installed a Sunfast top and find the material much tougher than the standard vinyl material, but still prone to cutting with an improper folding job.
Also, I never lock my car if and when I have to leave it alone (which is very, very rare) in a parking slot. Hooligans think nothing of slicing a top to access the car.
Like most LBC drivers, we tend to park in a spot that we can see it at all times. Kinda like a helicopter-mother at the playground.
T
Tinster
I place a small hand towel on either side
before I fold in the two side flaps. This
protects the top from scuffing itself.
d
Brosky
I agree with all except that I unzip my rear window and let it hang free. It allows the frame to drop down into the well further and I add towels between the folds on the side windows to prevent chaffing and scratch marks.
I usually put my top down in May and leave it down until November, unless I get caught in a downpour by accident.
jackag91
I haven't bought a new top, so I am completely ignorant on this.
Are the snaps installed when you buy a new top? The reason I ask is my snaps don't seem to line up between the top and the one's on the car's body.
Is it possible that the PO messed up installing the top or is it possible that the top shrunk so how?
swift6
Generally, the snaps are not installed, the snaps are not always in the same position on the car. If they are off by even an 1/8 of an inch it can be a nightmare so usually tops become specific to the car. Snap installation is pretty easy though.
Very possible that the PO messed up and installed the snaps before installing the top on the car.
TIP: Don't use the old top as a template. Get the top attached to the frame and locked in the up position before installing the side snaps.
The vinyl tops can shink AND stretch depending on the temperature. Age can also cause the vinyl to shrink. If its tight, usually an hour or so in direct sunlight can loosen it up.
jackag91
thanks. When I get the car off blocks I will sit it out side for a while and give it a shot.
John_Mc
The irony of this being that when it is warm enough out to soften the top to put it up, that's when you want it down! And vice versa. I have struggled often to snap those last snaps.
W Looking for tips: BJ8 roll up windows Austin Healey 10
6 Looking at first Healey and tips/things 2 look for Spridgets 18
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
