Looking For Photos?
BlueMax
I’m looking for photos of Datsun FL 5 speed sitting in chassis. The photos are needed from bottom, top, and front particular to the slave cylinder and release fork. Thanks!
smaceng
Here is my install using the Datsun 5-speed with a rivergate sourced slave cylinder. Sort of hard to take pictures from the top and sides once it is installed.
cheers,
Scott in CA
BlueMax
BlueMax
Thanks for the photo Scott; I was trying to see how close the slave cylinder came to the frame rail was the reason why.
I wasn’t planning to use the Rivergate slave cylinder, but a standard Nissan slave. I’m rerouting the hydraulic tubing from the driver side and welding a ”L” bracket for the hose to be supported. I wanted to see if the slave cylinder and release fork protruded over and above the frame rail to create any interference problems with the “L” bracket? Any other photos will help in the prospective without having to do a trial fit of the engine and transmission.
smaceng
First time I tried to use the std. BE slave cylinder with the adaptor that BillM provided, but it was too close to the frame for comfort.
Scott in CA
BlueMax
BlueMax
Thanks Scott, I think that I used a Nissan P/U cylinder. It tucks in close to the transmission bell housing but I did have to machine the adaptor to bring it out for the push rod to have a straight inclination to center the slave cylinder piston. I was wondering how much offset the CNC’s slave has? From your photo it looks to have a straight shot from the centerline of the piston to the pivot fork?
smaceng
The picture shows an adaptor plate under the slave, in order to shim it out. I don't know what that thickness is off hand.
BlueMax
BlueMax
As long as I have straight inculcation from the center line of slave cylinder to the center line of the release fork that I should not have any clearance problems, especially if I have to shim it out to do so. My line will come in from the bottom of the slave cylinder and bleeds from the top. From what I can see is that neither the pivot fork nor the clutch slave cylinder extends over into the frame rail which should give me clearance for my hose to loop around and slip under the slave cylinder. Thanks Scott!
Boink
Bronze
Man, I could EAT off that slave. [though I suppose you shot those photos right after the work was completed?] :yesnod:
Gerard
Scott in CA
Scott, I'm not sure why your original slave is so close, but I suspect that it's the way your rear mount was made. I use the same design slave mount with (minor improvements) and there is a lot more room between it and the frame than you show. These are the sort of details that are tweaked in my kit to avoid this sort of problem, but I've never seen one near this tight. I've yet to have a complaint about this.
Here's one from underneath on a '72 Midget.
BlueMax
BlueMax
Thanks for the photo Gerard; I do like your design using the OEM slave cylinder. In my situation I would not be able to attach the L bracket to the inside due to my oil pan would interfere with the bracket.. I can see that yours is in side the frame rail and not over it too, which is saying I should be ok. Thanks!
Gerard
Glad it helps. Thanks.
The bracket to hold the hose could be on the top of the frame or anywhere within the hose length. Only the 1" slave requires this, the 7/8" one uses a hard line.
Billm
The slave mount and trans mount that Scott got from me are the common Morrisservice ones that should be identical to Gerrard's- I don't know why it was so close.
BillM
smaceng
I used the adaptor for the speedometer, which may push my transmission over to the left. Gerard, can you use your 5-spd. transmission mount and use the Morrisservice speedo adaptor?
Scott in CA
Gerard
Scott in CA
I made some tweaks from the original Morriservice mount, but yes, Absolutely!
G
I'm looking for photos of thr chilli peppers but no one has produced yet.
nomad
Just wanted to note that the stock Datsun pickup slave is 3/4" while the stock slaves are larger.
When I went to get a slave to work on my Datsun 60 5 speed and A15 datsun engine setup the 3/4 datsun slave gave me pedal pressure that was brutal. I then tryed to fit the Morris Service stock slave mounting and had no clearance. I think I could have made it work if I had fitted it before the power unit went in. I'm not putting the blame on the adapter but on my installation. My modified trans mount and home built engine mounts are to blame. I ended up slotting the brit slaves bolt holes and turning the slave upside down. Can't bleed it correctly that way but the air seems to have worked its way out. I bled it as well as I could before bolting it up. The next one I do I plan to make my own slave from a weldment.
Kurt.
J AH Spares - looking for interior feedback/photos Spridgets 9
D New rollcage build - looking for photos Racing 3
tony barnhill Looking for XJ6 Photos Jaguar 6
MadRiver Looking for photos of Tiger dashboards Sunbeam (Rootes) 2
MadRiver Looking for any old dealership photos -- 1968 Triumph 2
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
