TR4nut
After 6 months of putting off replacing a tired clutch in my TR4, I did manage to complete the task on New Years day. Unfortunately I found that the finger-style pressure plate was badly worn also due to the use of a wrong throw out bearing, so I replaced everything.
Buttoned it all up, and it worked great.. for about a week. Although I was very careful with the slave cylinder and moved it out of the way when I pulled the transmission, after I reinstalled everything it wound up leaking which I finally figured out last weekend when it failed on me.
It's fixed again as I had a spare slave ready to go, but I think its taught me a valuable lesson - with the new clutch in place, the piston was running in a different area of the slave cylinder. I suspect that although the cylinder was in decent shape, the piston seal had developed a 'set' to it which caused the leak. That's my theory anyway, I'd be interested in hearing if others have seen that or have a different thought.
What that tells me that in the future (very distant future hopefully), if I do a clutch job I'll be thinking of changing seals in the cylinder at the same time.
Randy
Randy
