Leaf spring restoration
TulsaFred
Im working on my bugeye's quarter eliptic rear leaf springs today.
My plan is to disassemble the leaves, bead blast, and paint.
Any advice?
Should I paint the disassembled leaves or just paint the sides?
Grease between the leaves?
What paint?
Fred
Rut
Hello Fred,
I did the same to my 1/4 springs and used POR15 with their black top coat for UV protection. I would use regular chassis black if I did it again. I used Slip Plate graphite spray between the leaves instead of grease so it would not attract grit. I'm happy with the way it turned out, but like the touch up simplicity of Chassis black.
HTH, Rut
TulsaFred
TulsaFred
Tractor supply carries a different graphite product called easy slip.
I like the idea of a graphite product, thanks Rut.
OopsClunkThud
Member
I just did mine and used shoe polish between the leafs and rustoleum all over after they were assembled. The idea of easy touchup was my main motivation for this path. Have them installed but not driving yet.
TulsaFred
TulsaFred
Dang 4.5 hours to disassemble, clean and then bead blast all 17 leaves of ONE spring.
No wonder few people go to the trouble.
Im committed at this point so I guess the other spring will be tomorrows project.
I am going to draw the line at powdercoating them though.
Prime and paint with some graphite spray between the leaves, thats it.
F
bugedd
Its worth the effort to do it right, you will never have to do it again. And I think I have about 5 hours to disassemble, blast, paint, grease, and reassemble. POR 15 and a thin coat of grease between the leafs made it silent and lovely
Deleted member 9684
Sorry for the hijack, but does anyone have an original set of 1/4 eliptical they'd like to sell? Condition not important as i am planning to disassemble and restore. Thanks!
racingenglishcars
I have done many leaf springs on many British cars.
I have always used two component epoxy paint, and a trick I've never seen anywhere else, lithium grease. It's waterproof and won't wash away in the rain.
Rolls Royce and Bentley used leather covers for the springs to keep road dirt off, but I haven't gone that far yet.
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
F TR2/3/3A Leaf spring advice Triumph 16
Editor_Reid Unusual Leaf Spring Austin Healey 4
B Leaf Spring Re-build Options? Other British Cars 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
KVH General TR What Happened to My Leaf Spring's Nyloc Nuts? Take a Look . . . Triumph 17
B BJ8 leaf spring Austin Healey 2
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
K TR2/3/3A Leaf Spring "rebound clip" thickness .... Triumph 16
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
K TR2/3/3A Leaf Spring height and front spring pin removal again? Triumph 1
C Leaf spring length Austin Healey 4
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
T TR2/3/3A Leaf Spring "Silent Bloc" Triumph 3
stuntflyr Leaf spring toe-in modification viability Austin Healey 19
H rear leaf spring to chassis bushing Austin Healey 11
simon1966 Leaf Spring Refurbishment 100 BN1 Austin Healey 3
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
D Bugeye leaf-spring removal Spridgets 2
RCarr removing a leaf spring Austin Healey 7
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
Willie_P Newbie HELP: TR 3/4 leaf spring/axle installation Triumph 11
RAC68 Adding a Leaf to my Spring Leafs this Fall Austin Healey 15
K TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade Triumph 14
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
richberman how to: leaf spring bushing replacement Austin Healey 13
M need help new threaad 1/4 leaf spring Spridgets 6
PatGalvin TR2/3/3A TR3 Leaf Spring Rebuild - low friction tape? Triumph 9
aeronca65t Leaf Spring Re-Arc fixture Restoration & Tools 3
T Two quick leaf spring and bushing questions Spridgets 9
Tabcon Rear leaf spring bush size? Triumph 21
tahoe healey iron bushing removal rear leaf spring Austin Healey 6
tahoe healey leaf spring direction Austin Healey 8
tahoe healey leaf spring instaltion Austin Healey 14
prb51 leaf spring squeek Triumph 10
N Rear leaf spring brackets Austin Healey 9
T MGB-GT what is the length of mgb leaf spring,pin to pin MG 2
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
1965_MGB Leaf Spring Repair? [SFL] MG 6
Atrus Leaf Spring Front Bushing question Spridgets 6
Stig TR2/3/3A TR3 leaf spring maintenance Triumph 4
