1965_MGB
Greetings All,
While I was bored last night, I decided to detach the springs from my rear axle, and give them a looking over. It seems that the plastic spacers between the leaves is pretty much shot.
I have read that local spring shops can fix these up, but I don't see any listed in my area.
If any of my fellow Fla residents might know of a place, I would appreciate the info.
I guess what started as a simple bushing replacement is now going to a full spring rebuild, powder coat the brackets, and while I am at it, pull the axles and replace the seals. I might as well have the housing cleaned up and coated while I am at it.
When I get done with this "simple" project the underside of the car will look better than the topside ever will.
