GT6 Latest GT6 photos
JImEgan
Just felt like posting some photos.
New valence panels made out of aluminum.
Jim
Brosky
Jim, that looks really great. Are you taking it to Day of Triumph on the 29th at Lars Anderson Museum?
Hope to see you there...
J
JImEgan
I still need to register it. Plan is to do it by then. Have been getting no end of "good natured" grief from Eric and Dan.
Jim
trrdster2000
Jim, did you add a small scoop too your cold air intake on the outside of the front with a small wire mesh. Keeps out the bugs and at speed the air will not jump over the hole. so the scoop should be on the inside, toward the radiator to force air down the tube.
I did the same on the TR6.
Wayne
J
JImEgan
I did not, but like the idea.
Here is what it looks like now
Jim
trrdster2000
Nice, but you can see why a scoop and wire would be a benefit.
I would also shave the edge off the pipes. Or add the scoop to each pipe, making one longer than the other.
Wayne
UltimateQuestion
Very nice looking engine bay. Something I need to do on mine. Any pictures/thoughts on making the aluminium valences? Did you use the cardboard ones for templates?
J
JImEgan
I used architectural .040" anodized aluminun sheet for the panels. The angle is 1"x1"x.063" made on a sheet matal brake and yes, panels were copied from the original cardboard valences. A better material for the panels would .040" mill finish. I had to slightly glass bead blast the panels so the paint would have a rougher surface to adhere to. I have an eight 8' brake and shear, so cutting up a 4'x8' sheet of material was not a problem. Find a sheet metal shop near you that can shear the panel to square dimensions needed, then you can finish the cutouts with compound action tin snips. You will need left and right hand cutting as well as straight cuting.I have a spare right hand side and can get some dimensions as well as photos of it before paint.
Jim
trrdster2000
Jim, Well done, that should take care of it. You may be able to tell when the pressure is forcing some air down the carbs, kind of a little kick. Mine happens at 45 MPH.
Wayne
J
JImEgan
I like it. Two things I would do differently: add a M22x1.5 bung for fan sensor on top of radiator to left of fill neck and brackets for electric fan. I am returning radiator to Griffen Radiator in fall to have them do this.
J
JImEgan
When I repainted the spare wheel and got a new tire, I did not want to crank the securing nut down so much that the tire would get marks where the 3 spacers contacted it. I came up with this. It allows me to tighten the nut enough so that the wheel won't shift, but not enough to leave marks. I am sure that I must have seen something similar elsewhere, but don't remember where.
J
JImEgan
One last thing for tonight. I got a high torque starter and did not like having two solenoids: the original and the one on the starter. I used a relay to go from the igntion wire and supply 12 volts to the integral solenoid and to coil. I disassembled the old solenoid and converted it to a terminal block with the use of plexiglass
dklawson
Your starter looks very much like the one I recently installed on our GT6. I am very pleased with ours. It is a great improvement that I wish I had done years ago.
I like the custom solenoid/junction-box. Our car originally had the round pushbutton solenoid. When it died I needed a replacement quickly and fitted the Ford Mustang solenoid. It doesn't look original but it works and was certainly less expensive and readily available.
svtmikey
Bronze
That is exceptional......very nice work!!!
Mikey
drooartz The latest tool addition to the shop Restoration & Tools 25
C TR6 Latest TR6 updates and pics Triumph 10
Gliderman8 "Latest Resources" FORUM Help 2
Boink Sir Paul's latest video... with Frogeye! Spridgets 6
Rut Latest fluid recommendations Spridgets 5
K TR2/3/3A Tyre question, and an Latest Triumph 9
PeterK General TR Nice TR6 on Griot's Garage latest catalog Triumph 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
Drone Dog Lilly Engine Latest Austin Healey 14
Drone Dog Lilly Engine Latest / couple of questions Austin Healey 34
Rhodyspit75 Bugeye restoration Latest Spridgets 16
Michael Oritt Randy Forbes Latest Austin Healey 11
69MGC Latest Jaguar Digital Illustration Jaguar 0
Drone Dog Latest on Lilly Austin Healey 3
Drone Dog Lilly Latest Austin Healey 1
G TR4/4A Latest and greatest for water pumps Triumph 18
T TR2/3/3A Alternator failure Latest Triumph 17
PC latest tool score Restoration & Tools 4
simon1966 BN1 restoration Latest Austin Healey 2
Boink Nice Bugeye spread in the latest issue... Spridgets 4
CJD TR2/3/3A Latest Tires Triumph 38
Keoke Latest Upgrade Austin Healey 3
davidb Latest - AH 3000 steering box lubrication Austin Healey 4
davidb Latest - upholstery glue Austin Healey 14
Rut Bugeye Latest Spridgets 10
C TR6 Just an Latest Triumph 1
Got_All_4 General TR What to do in a "a" type Latest Triumph 9
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
P TR6 Latest compression test Triumph 11
K 9 year Latest Austin Healey 5
Keith_M Bugeye bodywork Latest Spridgets 2
PC latest tool hunt Restoration & Tools 15
J TR2/3/3A 59 TR3A Latest Video #2 Triumph 3
Kirk_Fisher TR4/4A Flood restoration Latest Triumph 1
me61ic 1963 BJ7 Resto Latest Austin Healey 2
Boink Healey appears in latest JibJab year summary... Austin Healey 1
B Resto Latest Austin Healey 35
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
U Spitfire Questions About My Latest Spitifre Triumph 14
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
T TR2/3/3A latest with my H6Ss Triumph 22
Mickey Richaud Off Topic One of Our Own in Latest Moss Mag... Triumph 9
A clutch Latest Triumph 0
P valve job Latest Triumph 9
bcliff T-Series TF Victor Latest MG 11
F TR4/4A TR4 Downdraft install Latest... Triumph 0
F TR4/4A Clitty Clack Latest on my TR4.... Triumph 5
M latest 6 pack!! Triumph 0
Mychael Progress Latest on the Frogeye. Spridgets 1
Banjo TR2/3/3A Latest of the TR2 sale. Triumph 22
