Karmann Ghia question!!! HELP!!
Platinum
On a remote locale, need torque spec's for the rear main axle hub nut on one of these things...
JackQ???
Mickey??
Mickey Richaud
Bayless
According to Haynes, if it is a swing axle then 217 ft-lb. For double-jointed it is 253 ft-lb. I know they are on there tight enough that I broke a good breakover trying to get one off once.
Platinum
Thanks, Mickey!
I couldn't find it to save me... You did. :wink:
tony barnhill
Great Pumpkin - R.I.P
You got a big 36mm socket, Doc?
Platinum
Yup.... but this wound up in a totally "Different Place"!! :laugh:
zblu
Worked on 600 ft/lb over here, or as tight as you can, which meant adding about 6' of pipe to the socket and then swinging on it!, allows for friction etc losses :smile:, mind you you have to tie the car down so the wheels dont slip/body lift!
Bayless
:lol: Dang zblu, you must have installed that one that broke my breakover trying to get it off.
Sounds like a mechanic frien when I asked him how much torque for some odd thing. His answer was "Just tighten it until you feel the threads start to strip then back off a quarter turn."
leecreek
And don't forget that cotter pin.
Platinum
Linin' up th' pin is th' REAL contest.
S 66 Karmann Ghia Cabrio on BaT Other Cars 0
W Awesome custom Karmann-Ghia coupe Other Cars 5
G Even Karmann couldn't grasp the wiper arm design Triumph 4
B Karman Ghia we just restored ....Cheers! Other Cars 2
vping Any Karman Ghia owners/wrenchers? Other Cars 14
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
