Jumping a battery safely
PeterK
A reminder
A neighbor attempted to jump start my mom's car in storage to take it for a drive. He's done this before. But this time he apparently reversed the cables (I have heard that some newer Japanese named cars mark the ground with RED).
Don't have the entire story yet since I'm not local. But good thing he was not near the car. He returned the cables to mom with all the insulation gone and the cables burned. He said there was a loud boom and something flew out of mom's car and cracked his headlight. He quickly exited and went home without explanation.
Her battery ws already at a low state of charge, the heat from shorting the cables heated up the battery, a little vapor leak and spark and the battery exploded. I still don't know where he was (mom was in her house) or what exactly happened. But good thing he wasn't anywher near the front of the cars.
My brother is taking photos for me today.
So BE CAREFUL, observe polarity, and let the discharged battery charge a little before attempting to start the car.
martx-5
If the battery exploded, there will be acid all over the place. I hope it got washed off, but it doesn't sound like it was if this guy just flew the coop. :hammer:
PeterK
PeterK
I expect to see a real mess. Told mom about baking soda slurry, an old paint brush and rubber gloves.
This guy could have been killed or blinded. Not good.
DanNagy Spitfire Jumping a dead battery on a Spit MK1 Triumph 7
Michael Oritt Battery Jumping Negative/Positive ground cars Austin Healey 31
J Jumping a Positve Grounded Battery Austin Healey 3
Joe Schlosser Bugeye Spedo jumping Spridgets 6
jlaird Miss Agatha jumping up and down Spridgets 0
vette PCV Valve, Jumping in With Both Feet Austin Healey 17
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
L How to smooth out a jumping fuel gauge? Austin Healey 20
tinman58 Old LBC jumping new muscle Triumph 1
B TR6 TR6 Jumping out of Reverse Triumph 5
H jumping out of 2nd gear Austin Healey 3
T Argh! Jumping out of second gear now Triumph 10
davidk Speedometer needle jumping Triumph 29
L Tach jumping, rough idle. Triumph 9
tony barnhill #5 Rocker Jumping off Pushrod MG 16
G Jumping Tach MG 4
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 7
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
