I've confused myself -- timing questions...
drooartz
Spring tune up time, and I'm working on getting the Tunebug in as good a shape as I can. I'm sure I'm dealing with worn bits almost everywhere, but I'd like to keep driving around a bit while the new motor is being planned/rebuilt.
2 questions for setting the static timing--I've managed to get myself confused:
1. To rotate the engine, I put it in 4th gear and push the car. Which way should I be pushing the car to check where the points are opening/closing (with a test light hooked up)?
2. To retard the timing, which way do I rotate the dizzy?
Side question -- I seem to remember that for Bugeye H1 carbs the mixture nut goes out maybe 6-7 flats for a starting point, instead of the 12 listed in many manuals. Is this correct?
Platinum
Good plan Drew! Don't let it atrophe!
1. Push the car forward to get the timing mark lined up correctly on the pulley (with the iggy OFF). I believe it should be in the 8°~10° BTDC (Before Top Dead Center) position. THEN connect the test light to the coil L/T lead going to the points, and ground. Turn the dizzy clockwise first until the light goes out, then back until the place where it *just* comes on...
2. Dizzy runs counter-clockwise, so to retart timing turn it in the direction of rotation (C.Clockwise).
2.x I always start with 12, and tweak until the piston raise response is correct. Some may have other 'ways'. We'll see!
drooartz
drooartz
Thanks, Doc. Comforting to know that I was doing the timing correctly.
jlaird
Miss Agatha was happy with eight.
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Jagguy MGB Ignition timing issues....I'm getting confused! MG 16
JimTR4 TR4/4A Coil - easily confused... Triumph 6
catfood Confused... again! Austin Healey 2
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
Trevor Jessie Confused about top down driving weather [off topic] Spridgets 43
DNK TR6 Well I'm a Little Confused Triumph 4
G MGB I may be confused :[ MG 5
J Confused about Bugeye windshield to body seal. Spridgets 15
JPSmit Need a MOWOG and very confused Spridgets 13
N TR2/3/3A Confused TR3A owner Triumph 5
KLUTZ Confused with my Overdrive wiring.. Help please MG 3
G Confused about the oil separator Triumph 7
1 a confused idle Triumph 8
jjbunn Confused about stalks Triumph 5
L Spitfire Bit confused by my Spitfire coil wiring... Triumph 10
timbn2 confused on tranny covers.... Austin Healey 7
10musketeer Confused with starting/ignition/timing Spridgets 63
ncbugeye Confused by digital timing Spridgets 5
bravenrace I'm Really Confused TVR 13
KLUTZ Now I am confused, Re: Filler. MG 40
jjbunn Confused about gear stick/shift knobs MG 14
R TR6 Confused over TR6 Engine Number Triumph 5
G Now I am really confused.... Triumph 2
prb51 TR2/3/3A Tr3 conFused Triumph 7
daddytiger64 Confused... Sunbeam (Rootes) 9
UltimateQuestion GT6 Bodywork amateur - What have I gotten myself into? Triumph 19
H Do it myself service tracking? Restoration & Tools 3
H second guessing myself-oil thrower question Austin Healey 2
H gas tank repair 100/6 without killing myself Austin Healey 11
D TR4/4A Finally introducing myself and the TR4a Triumph 15
Lukens TR2/3/3A Sometimes I wonder about myself. [TR3 related] Triumph 5
drambuie Pit crews of the 1938 Grand Prix's [Next time i will jump out and refuel myself] Austin Healey 1
C Wedge Just reminded myself what a great car the TR8 is. Triumph 29
CZ_Dave I couldn't help myself! MG 10
PATR8 Wedge why do I do this to myself? TR8 engine rebuild Triumph 26
drooartz Fitting a top myself? MG 5
H Challenging myself on wire wheel color choice Austin Healey 22
M Dug myself into another hole Spridgets 5
W Do I do it myself? Spridgets 23
danstr6 What have I got myself into Triumph 3
M Before I Get Myself In a Heap of Trouble..... Spridgets 4
DanNagy Gave Myself a Wedgie Triumph 19
philman proud of myself today! Triumph 8
2wrench Should I attempt lower end rebuild myself? Triumph 34
G allow myself to introduce Spridgets 18
G I think I am going to shoot myself................ Triumph 26
J why do I keep doing this to myself? Triumph 2
J rear hubs...Something I can rebuild myself? Triumph 24
MadMarx Hello -- may I introduce myself Triumph 11
